New #'s with stock 3.5" D1SC IC's
Old 10-04-2007, 05:28 PM
Moz
Moz's Avatar
Default New #'s with stock 3.5" D1SC IC's
676RWHP
624RWTQ
@14psi
Any Guess on track time with ok driver?
Old 10-04-2007, 08:53 PM
Moz
Moz's Avatar
Wow, you guy's are a cold crowd!Nobody has a guess on E.T's or MPH?
Old 10-04-2007, 08:59 PM
98turbls1's Avatar
Hard to say borther... I would say that if you can get a good launch you'll definitely be in the 10's if your suspension is setup....Wow, are you still on the 5.3 heads??? Is your compression crazy high??? I'd like to know a little more on this...
thedudeZ's Avatar
mid/high 10's@125+ depending on tires/track condition/driver mod
Old 10-04-2007, 09:01 PM
kp
kp's Avatar
Not a cold crowd, what kind of tires/rear end and how much does it weight and how much are you willing to beat on it?
I can see anything from 11.90 to 9.90..
Old 10-04-2007, 10:50 PM
EPP
EPP's Avatar
Exclamation
Originally Posted by Moz
676RWHP
624RWTQ
@14psi
You better watch your inlet air temps with those intercoolers. Back to back runs can be fatal. Bob
Old 10-04-2007, 11:05 PM
98turbls1's Avatar
I agree... Ever thought about meth injection?? Might save you a bit... Do you know your compression??
Old 10-04-2007, 11:26 PM
Moz
Moz's Avatar
Compression 9.54:1
3400LB's
Moser 12 Bolt / 33 spline / 3:73 posi
BF Goodrich 325-50-15 DR
Q1A's all around
Old 10-04-2007, 11:27 PM
nvmy2000ss's Avatar
That is what I was going to ask when I first looked at this post but didnt have time to reply. So what is your iat's?
Old 10-04-2007, 11:39 PM
Moz
Moz's Avatar
Yes,I also agree.Will find out Sat. what the IAT's were.I use the car as a weekend cruiser one/twice a month.If I were doing some strip duty the intercooler's would be upgraded.I will run the car 2-3 times just to see what it will do at the track.99% of the time it will be street driven.
Old 10-04-2007, 11:49 PM
Moz
Moz's Avatar
I would like to go with 6.0 heads but i'm a little strapped right now for more toy's (upgrades).Should the IAT's be alright with street cruising with the 9.54:1 comp???
Old 10-05-2007, 12:04 AM
kp
kp's Avatar
I would say 10.50 @ 130, just use some good gas. The IATs will go up pretty quick at the track but for cruising and an occasional blast it should be OK. Maybe look at a meth kit for some insurance.
Old 10-05-2007, 08:18 AM
rufretic's Avatar
I agree, 10.5 @ 130 sounds just about right if you can drive. My set-up is making about the same power and thats about what it runs.
Old 10-05-2007, 08:32 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
11.7@127 - 9.9@136. How fast have you been in that car before?
Old 10-05-2007, 02:28 PM
texada's Avatar
I would think that the mph would be higher than 130.
Old 10-05-2007, 04:59 PM
Moz
Moz's Avatar
The IAT's on the dyno were around 130's.
Old 10-05-2007, 05:28 PM
black_z's Avatar
Mid-low 10's@130-135. My cam only car went 119 running out of gear with 370 WHP (mustang dyno)
Old 10-05-2007, 07:03 PM
LS1 SPEED's Avatar
IAT's are on the high side
We recommended a FMIC and custom inlet once he recovers from this round of mods/repairs.
The car has a good amount of power left in as most know/see here.
The race fuel at the track would also be a good idea, but as mentioned the around town occasional blast should be o.k.
The car should do well once you get some seat time in the car. We will see you Monday Chris
thanks
BTW : 10.40 @ 135
Old 10-05-2007, 07:17 PM
30th t/a's Avatar
I say 10.8@132
Old 10-05-2007, 11:22 PM
Moz
Moz's Avatar
thanks
BTW : 10.40 @ 135
Thank You Larry for making my car enjoyable to drive again!When the time come's to upgrade to the mentioned above,you will be seeing that black TA again.
If anyone is curious about Speed Inc. if you already don't know.They are indeed TOP NOTCH!!!
