Drag Racing Tech
Fabricated lines for Strange manual master cylinder? How do you connect SAE to metric
Old 10-06-2007, 05:57 PM
9 Second Club NA
Dragaholic's Avatar
Default Fabricated lines for Strange manual master cylinder? How do you connect SAE to metric
I plan to install my Strange manual master cylinder this weekend and wanted to know once I fabricate my own lines, how am I going to connect the new lines to the factory lines? The master cylinder uses standard (SAE) lines and the factory lines are metric. TIA!
Old 10-06-2007, 06:48 PM
Kingsize's Avatar
It should have come with the fittings to change it from SAE to Metric. Mine did.
Old 10-06-2007, 10:16 PM
Jantzer98SS's Avatar
I plan to use the stock metric lines with the sae fittings that were provided. I just rebent my stock lines and cut what I didn't need.
Old 10-07-2007, 03:22 AM
TwoFast4Lv's Avatar
I have found makeing meteric bubble flares is MUCH easier then Double flares. Now I just buy standard lines and I have a bunch of Lines left over from installs with metric fittings. I just bend my lines up and then install the metric fitting and flare it. DONE!
Here is a shot. I made ALL the lines.
Old 10-08-2007, 06:46 AM
9 Second Club NA
Dragaholic's Avatar
Have you guys successfully reused the stock lines by simply rebending them? Did you have to cut and reflare? I THINK I found the adapter fittings in the bag that I didn't pay any attention to.
Old 10-08-2007, 03:26 PM
Restricted User
1fstGM's Avatar
I have been thinking of going with the ABS delete kit and manual braking system. What are you guys using for this and what are the prices around? Also how is braking when doing this with the stock braking system? Thanks.
Old 10-08-2007, 10:22 PM
tektrans's Avatar
I used the Burkhart ABS block.
Attached Thumbnails Fabricated lines for Strange manual master cylinder? How do you connect SAE to metric-abs1.jpg
Old 10-08-2007, 11:11 PM
TwoFast4Lv's Avatar
That Burkart looks good. I have also installed teh SJM kit. VERY complete and best directions I have used in a while.
Mine? the one in the picture there was a E-bay jegs special $26 to my door for the porportioning valve and $39 for the Line lock.
Old 10-09-2007, 06:31 AM
9 Second Club NA
Dragaholic's Avatar
I drilled the pedal assembly yesterday evening, reinstalled it, installed the master cylider and I don't see how you guys are reusing the stock brake lines by simply rebending them. They don't even look close to reaching/fitting. The stock master cylinder has the threaded fittings on one side and the Strange has it on the other.
Old 10-09-2007, 09:36 AM
9 Second Club NA
Dragaholic's Avatar
So do I need to buy a bubble flare kit or double flare kit?
Old 10-09-2007, 09:50 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Post pics of how you drilled the pedal and ill give you the answer....lol
Old 10-09-2007, 11:41 AM
9 Second Club NA
Dragaholic's Avatar
I posted in yoru thread.
Old 10-09-2007, 11:47 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
A bubble flare kit will cost you lots and lots of money, your best bet is to buy the 3/16 European flared lines they have at NAPA for the stock connections and then just use a normal flare for the master cylinder.
but a good 37* and 45* double flare kit is always nice to have.
Old 10-13-2007, 04:30 PM
9 Second Club NA
Dragaholic's Avatar
The kit gives you the adapters that go into the master cylinder, but what I need is the adapter that adapts 3/16" line to the metric bubble flare on my Billingsley ABS delete block.
Basically, I need a fitting that threads into a 12mm bubble flare and in the center of that fitting is tapped for flare 3/16" line.
Quick Reply: Fabricated lines for Strange manual master cylinder? How do you connect SAE to metric
