Front Wheel Studs
Front Wheel Studs
What length is everyone running in the front with shank style lugs so they extend out a bit?
Who did you buy them from? A few of mine are bent and it's been so long i don't remember witch ones i need i know they are 12mmx1.25.
Race your car!
I haave the 3.25 ones, and tehy stick out of the end of my lug nuts a touch more then the dia of the lugnut itself. This is with Bogart's and the standard spacer they weld to the inside of the wheel to clear the stock brakes, and with summit open ended shank style lug nuts.
I believe or it used to be your threads must stick out at least 1/2 the diameter of the stud, i.e 1/2" stud must have 1/4" thread showing past the lug nut.
Also remember wheels like prostars and draglites are much thicker in the center than a bogart or Alumastar rims.
With weld draglites or pro-stars you'll need the longest arp studs. The rims are extremely thick in the center. For tech, the threads must engage into the hex portion of the lug nut. They do NOT have to stick out past the lug nut. I'm pretty sure they must engage the width of the stud itself into the hex portion, someone with a rulebook handy will chime in soon.
