First LS7 Clutch Install
Old 10-19-2007, 11:50 AM
JUSTONY's Avatar
Default First LS7 Clutch Install
ok, so like the title says this is my clutch install so I appreciate all the help I can get. I have decided to go with the LS7 Clutch/LS2 Flywheel setup on my 99 Camaro.
I just wanted to make sure that I order all the right parts, so does this kit include everything I need
http://www.byunspeed.com/product_inf...0d955e4c4eb30a
I am ordering the new slave, but do I also need to order the flywheel bolt kit and GM Hydraulic Clutch Main Cylinder/Rod???
Does anyone have any link to any step by step LS7 clutch installs with pics???
Does the price for the kit look reasonable???
Thanks for the help!
Old 10-19-2007, 11:54 AM
JUSTONY's Avatar
Oh, yeah.......... do i need to replace the throwout bearing as well???
Old 10-19-2007, 02:46 PM
BIG_MIKE2005's Avatar
Does you clutch pedal currently give you problems?? If your anwser is yes, then you'll want to replace the master also.
The slave & throw-out bearing are one assembly on these cars, so buying the slave is good enough. You might pick up a new pilot bearing though.
The install is VERY simple & straight forward. It installs exactly like a stock clutch. No guess work involved. You can also either re-use you stock flywheel bolts with some red loctite or upgrade to the ARP hardware.
I love my LS7 clutch & its been installed for over a year now. I daily drive it 300+ miles a week in town/highway. No chatter & it feel like a stock clutch except it holds alot better. It has handled my current H/C combo without a problem so far.
Old 10-19-2007, 02:57 PM
djsanchez2's Avatar
^^good to hear. Just ordered mine right now.
OP- the install is pretty easy, i've done a couple on friends cars. This is my first non-stock clutch. Finally burnt up the old one.
Old 10-19-2007, 03:24 PM
JUSTONY's Avatar
Thanks a lot for the help!
Just ordered the LS7 clutch kit, slave, and new bolts so hopefully I should be all set! Knock on wood, hopefully I will be ok without replacing the master cylinder
Old 10-19-2007, 03:57 PM
I'm on my stock 99' master cylinder with a little over 107k on the clock. They are just kinda hit n miss. They either last for a long *** time or they go out earlier than you would think it should.
Old 10-19-2007, 05:15 PM
JUSTONY's Avatar
Yeah, mine just rolled over 100k, so hopefully it has more life left in it since I didnt order a new one!!
Old 10-19-2007, 06:34 PM
Grifter's Avatar
I work definately recommend getting a new pilot bearing. You're in there anyway, no reason not to.
Old 10-21-2007, 06:33 PM
EvilCamaroSS's Avatar
do you have to use a LS2 LS7 flywheel? could i use my Fidanza Billet steel flywheel with an LS7 clutch?
Old 10-21-2007, 07:55 PM
_JB_'s Avatar
Yes you have to use an LS2 flywheel, the clutch and flywheel are bigger than an ls1/6 setup.
Old 10-21-2007, 08:55 PM
3.4camaro's Avatar
They are a BITCH to get out. I had a slide hammer on mine for 20 minutes trying to get it out.
Old 10-21-2007, 10:18 PM
Grifter's Avatar
I guess it depends on what tool you use and how old the car is. I just removed/installed one in an 06 GTO. A slide hammer got it out in about 30 seconds.
