Weird problem?!?
Weird problem?!?
My car has been acting up recently and i think it is due to an electrical issue, let me tell you what it does. When I first start it the voltage is often high like 16volts and after driving for a little bit it begins to fluctuate drastically. It often dips down to 10 volts and then randomly jumps up to 16volts again, I have changed the alternator to no effect 3 times. I have a weird *** looking solenoid on the firewall that everything is routed to and from, do you think this could be causing my issue? I would think that something is drawing mass amounts of voltage and then stopping and that is causing my fluctuations. There is no consistency to this problem and it is driving me insane, any insight would be helpful.
-Jeremy
-Jeremy
Mine does it when its cold too, like I said its inconsistent. What could cause this problem? If something was drawing and releasing power randomly it would cause this right?
