Who has a SPEC stage 3+
Old 10-22-2007, 11:34 AM
EvilCamaroSS's Avatar
Default Who has a SPEC stage 3+
And how long has it lasted you? mind you were not talking about the stage 3, we are talking about the stage 3+
I'm thinking of putting one in to replace my spec stage 2, with my fidanza billet steel flywheel.
anyone else have the same setup?
Old 10-22-2007, 11:45 AM
brad8266's Avatar
I have a 3+. Mine lasted around 10K and only died because I let a girl drive it when i was drunk once and she slipped the **** out of it and glazed the flywheel. You cant slip any aftermarket clutch like she did and expect it to live. Im talking about 3k slippage upon start and slipping it during shifts. Oh well.
Anyway I put another 3+ in and I like it just as much as I did the first one. Nice and streetable and holds the ~650 RWTQ with no problem. Nobody drives my car ever again.
Old 10-22-2007, 11:50 AM
haha I have about 12Kmi on my spec stage 2 when it died, i let my friend drive it cause he works for a tire shop, and i thought my wheels were bent, well he slipped it too much and then it started slipping under load in the higher gears i coulda made it last another few thousand miles but, same as you no one drives my car ever again!
Old 10-22-2007, 03:34 PM
anyone?
Old 10-22-2007, 04:07 PM
Sharpe's Avatar
12K and still holds on my bolt-ons Z28 like the day I bought it. Only been to track once for two passes. Driven hard on street. Car sees red more than once every day in first three gears. I've NEVER had ANY chatter or any other problems/issues. Stock-like drivability.
In short, it's perfect in every way and always has been. It's also by far and wide the most common aftermarket clutch for our cars. With the glazing problems I've read about with the LS7, there's no way I would chose it over the SPEC 3+.
Old 10-23-2007, 07:05 AM
black01_WS6's Avatar
I have had it in for about 10k and had problems with install at first- no shim provided, but after it got fixed all has been well. It has been taking 5k dumps at the track and still driving it home.
With our cars getting higher mileage I would replace the slave at the same time as I have been seeing people putting in clutches and having problems soon after- and the slave is the problem.
Old 10-23-2007, 03:38 PM
PewterScreaminMach's Avatar
My brother's 3+ lasted 3,000 miles. We don't know if it was a fluke or what, but his Stage 3 died after 10k and my Stage 3 after 8k.
I know I was driving mine very poorly at first (slipping and riding it a lot since I had never had a manual car before and didn't know any better), but it still lasted 8K with that abuse, so we don't know why his 3+ only lasted 3,000. He is an ASE tech who worked at a Chevy dealership for quite some time, so I don't imagine it was his driving that did it. I know it's much more rare than most people think, but it may have been faulty from the factory. I believe he bought a Ram clutch to replace it, so we'll see how that goes. I know he's not happy with Spec.
I now have a Spec Stage 2 in mine and have learned how to drive (after a lot of research and practice BEFORE the new clutch) and I went with it because I was told it would hold my power and last a long time since it is a kevlar disc. I only put down 367 rwhp but the clutch gets a tad bit soft after getting on it a bit. I've bled it multiple times and it has not gone away. I need to call Spec about this.
Just thought you'd want the input.
Old 10-23-2007, 04:01 PM
sounds like the shim's wern't installed, my stage 2 lasted about 12K with no shim and it would have been less if not for multiple 300-400mi road trips
Old 10-23-2007, 06:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
The shortest I've seen one last was 15k miles.The longest was 30-35k with alot of track abuse.
Old 10-23-2007, 06:43 PM
raceme@you'dlose.com's Avatar
My stage 2+ lasted less than 10000.
Old 10-23-2007, 07:28 PM
2thousand2's Avatar
I have had mine in for 20k at least. This was used when the car was stock launching at 6k with mt drag radials AND with H/C/n2o making 560 rwhp. I would buy another one for sure.
Old 10-23-2007, 08:06 PM
LS1TECH Sponsor
badpewter-z's Avatar
i had the orignal 3 x pad and got over 30k on it before i swapped it for my stg 5. im thinking of getting a 3+ to replace the 5 now if that tells ya how i feel about spec
i beat the **** outta my stg3 too
did the breakin and not a "slipper" type of driver
Old 10-23-2007, 08:30 PM
I do slip it at the track a little but thats because i value my rear end, on the street zero slip
Old 10-23-2007, 09:37 PM
shoemike's Avatar
i have a stage 3 with 32,000 miles and highly abused.(460HP)
not to sure for how much longer.
Old 10-24-2007, 11:24 AM
I couldn't tell, but if this was in reference to my post, the shims WERE installed. I was originally nervous about this when I got it back together and the engagement felt very different and lower, but when I pulled it back off, we found the shim on there in all cases. There seemed to be no issues with any of them regarding clutch disengagement.
If that was in reference to someone else's post, just ignore what I said .
Old 12-11-2007, 11:57 AM
98camaroLS1M6's Avatar
Oh wow, that's good to hear. I've heard a lot of people who have had problems but I'm glad to see they can last. It seems to be a hit or miss, not sure why people are having the pressure plate explode on them? Does spec really have that many defective ones, or is it due to install or driving?
Old 12-11-2007, 01:30 PM
firechicken_98's Avatar
I think all the clutch manufacturers have issues. You name it and someone on here is complaining about it.
I just did my swap and I put a Spec Stage 3+ in my car. So far so good. The only thing that's slipping now are my tires. I'm hoping it will hold my 500+rwhp.
Old 12-11-2007, 05:44 PM
Yeah, it seems that no clutch company is perfect.
Old 12-11-2007, 06:16 PM
1QWIKBIRD's Avatar
I've had my Spec 3+/aluminum flywheel for 8k and no problems to report. I auto-x the car, dump it at 4500 at the track, dead hook and go.....No chatter. Good clutch. New slave at time of install, spacer installed, remote bleeder installed, McCleod Blowproof bell installed all at the same time.
I think some of the problems stem from guys installing the clutch and then not properly breaking them in. I called Spec and they recommended 600 to 800 of non-highway miles to properly seat the clutch assembly. That's a pretty tough thing to do, given the temptation to simply roll out the driveway and let it happen.
My 2 cents.
Old 12-11-2007, 07:26 PM
1BADAIR's Avatar
my spec 3 x-pad has over 25k on it and still works great. 1.45 60's and enough to break the 12 bolt a few times
Quick Reply: Who has a SPEC stage 3+
