ok pissed off!!!!!
Old 10-28-2007, 04:51 PM
Z28LS1camaroguy's Avatar
Default ok pissed off!!!!!
ok just got my t56 put in like two weeks ago, been goin easy on it letting the clutch get broke in. But still for some odd reason 5th gear grinds and now when ever i push the clutch in it makes a grinding howling noise that i dont know what the hell it is, im really pissed off at the shop that installed it and it was rediculous getting my car back in the first place and now i have to take it back up to them to fix what ever the **** is wrong with it now. what is that noise also??? it just started.
Old 10-28-2007, 04:59 PM
camaroguy26's Avatar
you know mine's been doing the same thing. I did the M6 swap from my A4 almost 2 years ago now and 5th grinds every now and then. Never troubleshot it or looked too much into it but I think the clutch doesn't release fully sometimes when it grinds. and the noise started happening recently but it's not every time, just when I hold the clutch in for more than maybe half a min? but I believe it's just the throwout bearing going bad. Did you get a new slave or reuse your old one? Mine was used with about 10,000 miles on it when I put it in. It's about time for a new clutch, hydraulics, and rebuild.
Old 10-28-2007, 05:13 PM
i guess they used an the old slave, the tranny only had 9000 miles on it and new clutch. Will it be ok to drive it up to the shop tomorrow??? i mean i dont want to mess it up nemore, and im really pissed off since i just got my car back on OCTOBER 16. I mean this is bullshit and they better get it fixed right or im getting my money back and going somewhere else.
Old 10-28-2007, 05:18 PM
ls1 joe's Avatar
Just miss 5th until you get to the shop. Go 4 to 6th and you should be okay.
Amber
Old 10-28-2007, 05:25 PM
no but its not just 5th, its when i push the clutch down slowing down i get a howling noise from the tranny, i dont know what it is and its freakin me out. and this is in any gear.
Old 10-28-2007, 06:08 PM
85camarocrazee's Avatar
Either make them pay for a tow and repair it ight this time, or get all of your money back and send the thing off to Amber and the guys at six speed inc.
Old 10-28-2007, 06:12 PM
yeah but the thing is i got the trans from him and he said its a brand new trans basically, im just tired of not havin my car, i want it fixed and running good. and with all of this bullshit im getting really frustrated, plus i did the break in period and only really got on it once but shifted at 4k rpms. I think they didnt take there time and rushed this thing in and didnt do it right.
Old 10-28-2007, 06:40 PM
Mike44138's Avatar
Your throwout bearing is screwed up. That's the howling you're hearing when you push the clutch. 5th gear synchro's probably bad too.
Old 10-28-2007, 07:13 PM
ls1 joe's Avatar
If the noise is only when you push in the clutch then yes it is the throwout bearing. If the noise is always there then no it is not. I would call and ask them to pay for a tow if you are truely concerned with driving it and since none of us can hear the noise you have to make that decision. Good luck and hope it is something stupid you can get fixed in a day.
Amber
Old 10-28-2007, 07:26 PM
thanks me to i hope things work out, but it just seems like all this has been a major hassel and i cant enjoy my car at all.
Old 10-28-2007, 07:27 PM
also should i drive it or should i have it towed i dont really have time to get a tow truck and it seems to drive fine.
Old 10-28-2007, 07:37 PM
Ta'sWs602's Avatar
im havin the same problem as well installed a rebuilt tranny havent really got to drive hard due to breakin in the clutch but have about 200 miles on it now but 3rd and fourth is grinding really bad but whats weird the rest of the gears are fine i have to slam it into gear so it does not grind this tranny **** is really pissin me off and the other night just driven normal and it got stuck in fourth gear and eventually came out but it took some effort please help???? thanks trevor
Old 10-28-2007, 08:39 PM
Definitely does seem like a pilot bearing but I'd be towing it back neway. I'd use a bushing in it's place. All of them little bearing pieces can really mess up an input shaft.
Old 10-28-2007, 09:26 PM
i dont really have the time to tow it, i think i will be fine just driving it nice and easy up there. its mostly highway so ill be in 6th the whole time.
Old 10-29-2007, 06:36 PM
Ta'sWs602's Avatar
Old 10-29-2007, 08:54 PM
thesource's Avatar
Sounds like you had someone work on it that didn't know what they were doing or over looked something when installing it . The 3/4 shift issues sound like something is fubarred in the syncro assembly . Maybe bad rings or even screwed up keys or both ...........
