Is it ok to run the ATI race bypass valve?
Old 10-30-2007, 08:50 PM
allthrotle's Avatar
Default Is it ok to run the ATI race bypass valve?
Can you run the ATI race bypass valve or the vortech mondo bypass valve on a d1sc thats only using 5-7lbs? Im sure the stock bypass included in the kit is more then enough but, the stock one recirulates and these two dump to the atmosphere. Is it also ok the dump to the atmosphere or does that make the maf go all crazy?
Old 10-30-2007, 10:37 PM
b727pic's Avatar
If its set up right, the MAF will never know.... you should be "dumping" before the MAF ever senses it.
Old 10-30-2007, 10:50 PM
badnoma's Avatar
anyone have a sound clip of those two bypasses? I had the stock one that just recirculates. I didn't like it. Never heard the other ones though. post em up
Old 10-31-2007, 02:04 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I use the Mondo vented to the entire world. The Mondo is louder than the supercharger.
Old 10-31-2007, 06:11 AM
NA$TY-TA's Avatar
I have the ATI and its loud as hell. quite a few of the Turbo guys use it too.
On the 1st pass you can hear me let out when i start to spin and thats the bypass... its loud as hell.
http://itlxlr8.com/vids/Track%20Vids...rch%202007.mpg
Heres one on the dyno.... Turbo kinda drownds everything out LOL
http://itlxlr8.com/vids/VA%20Speed%20Open%20House%2012MAY07/NA$TY-TA%20VA%20Speed%20Open%20House.mpg
Kyle
Old 11-16-2007, 04:32 AM
One Bad Z's Avatar
Maf? what maf? SD-tune F T W!
Im in the same boat too. I have the old supplied ati valve. Race version is $400 but ProFlo is $140. I need something that can be adjusted to make boost in lower rpms.
Old 11-16-2007, 05:03 AM
EPP
EPP's Avatar
Thumbs up
You will save money going through us.
http://www.exoticperformanceplus.com...html?item=1261
Old 11-16-2007, 06:29 AM
LS1Tech Sponsor
Slowhawk's Avatar
If you use the ATI on your low boost level make sure you manually shut the valve a bit so it doesn't bypass too much air while cruising.
Old 11-16-2007, 07:46 AM
Which of the two is louder the Mondo or the Big Red? Does anyone know?
Old 11-16-2007, 08:08 AM
One Bad Z's Avatar
Thumbs up
wasnt on the website the last time i was on there but i do believe i found an x-mas gift for myself.
Old 11-16-2007, 02:52 PM
TS6
TS6's Avatar
Yeah Bob, I might be getting one from you too.
Old 11-16-2007, 03:10 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I ran the big red on my stock shortblock setup at ~6psi. I love it!
Old 11-16-2007, 04:42 PM
No Juice's Avatar
You can vent the stock one to atmosphere, I do. It doesn't need to be recirculated
