trany problems(t56) ugh!
Old 11-01-2007, 06:50 PM
tailpipe's Avatar
Default trany problems(t56) ugh!
if the car is say...sitting at an idle, and i move the shifter towards 3rd gently, it grinds, same with 4th. it grinds also. along with the fact that now it seems to get stuck in 4th all too often. happened out of nowhere (casual driving)
this pretty much all started last night.
any ideas???
Old 11-01-2007, 07:31 PM
chuckyt1's Avatar
What's it do when driving? Any grinding then? Might have lost the keys in the slider...
Don't grind fourth. That's an expensive gear to replace, (it's the input shaft).
Shoot a pm to, or call, Amber at SixSpeeds Inc. She is very helpfull and will answer all your questions.
Old 11-01-2007, 11:12 PM
tailpipe's Avatar
Default t56 troubles
umm while driving, its does grid going into 3rd and 4th but ive stopped putting it in 4th cuzz it just gets stuck
Old 11-01-2007, 11:44 PM
_JB_'s Avatar
Be ready for an expensive rebuild, mine did the same thing.
Old 11-02-2007, 01:25 AM
SSMOKIN_Y2KSS's Avatar
im interested to see if anyone has a good explanation for this because today mine started to do the same thing but it gets stuck in 3rd mainly 4th occasionally..and mines built too! im pissed
Old 11-02-2007, 08:51 AM
tailpipe's Avatar
anyone got a price range for a rebuild
Old 11-02-2007, 08:53 AM
chuckyt1's Avatar
http://0174de9.netsolstores.com/inde...ATS&Category=2
Old 11-02-2007, 11:58 AM
thesource's Avatar
Definately sounds like the keys in the slider assembly are fubarred and need to be replaced along with the syncro rings and update the shift fork as well .
Old 11-02-2007, 11:33 PM
_JB_'s Avatar
I ended up replacing 1-4 gear, rear main shaft, and using sixspeedsinc's 5A rebuild kit with bronze 5-6 fork pads. Good luck!
