Drag Racing Tech
Bunch-o-questions about drag racing-Knock retard-Drag Radials-Wheel Hop
Old 11-12-2007, 02:47 PM
Dr.Accumulator's Avatar
Default Bunch-o-questions about drag racing-Knock retard-Drag Radials-Wheel Hop
The setup:
99 FRC 6speed- H/C/I/ all bolt-ons + 175 = shot 588 RWHP 664TQ on mustang dyno
3.90 gears
18" BFG DR @ 20psi
Spray 3000-6000 RPM on full bottles heated to 1000 psi
launch at 2500-2800 rpm
Problems at the track:
Wheel hop
Lots a spin
Knock retard??
1.8-1.9 60 fts
118 traps
mid 12-13 sec runs = WTF?
nailing every shift @ 6200
I need some damn help.. the current theory is wheel hop and hard shifts = knock retard and killing my power, and im running the rest of the track amputated. Why so much wheel hop on DR @ 20 psi? Spray was not hitting hard at all. Im gonna break all the lines and inspect/clean them and install a plate - delete nozzle. Ideas?
Old 11-12-2007, 02:57 PM
04blowngoat's Avatar
I would look into one of these: www.scangauge.com. Best 160 bucks ever.
Monitor your IAT, IGN, MAP, & AFR. Sounds to me like someone needs to check their tune. What plugs you running?
Wheel hop or hard spin wouldn't hold back your traps THAT much with those numbers, if accurate.
Old 11-12-2007, 03:03 PM
I have two Interceptor OBD2 scan gauges http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=interceptc5|0 i need to hook up.. the will be on the car when we go back..
The spray wasnt hitting hard at all ..gauge on full bottles was steady @ 1000psi.. im gonna break and clean lines
Old 11-12-2007, 03:05 PM
1lejohn's Avatar
Thats alot of power for drag radialsl to hook up. How old are the tires? How does it run on motor,does it hook up,spin or wheel hop? Do you know for sure that you are getting knock retard? Have you done any suspension work? Wheel hop is the tires loading up(gripping) and then slipping very quickly. It will break stuff. On my car I can't hook up on drag radials while spraying,even with a .5 sec delay. We need some more info on you combo.
Old 11-12-2007, 03:23 PM
no suspension work..stock IRS w 3.90s... drag radials are almost brand new.. DTE brace on trans/diff....motor runs were anemic at best. 13.xx ET with wheel hop and spin depending on launch.. no delay on spray..3000rpm - 6000rpm. not sure on KR.. just some opinions from trackside..would explain the shitting runs even after hooking 1-2 shift
Old 11-12-2007, 04:23 PM
chrismorales75's Avatar
Sounds like the intersection point is off and you need some adjustable shocks.
Is the car lowered?
Old 11-12-2007, 04:24 PM
cbra-klla's Avatar
suspenson, suspension, suspension.................the key to hooking up and not wheel hopping. i dropped the clutch at 5500 with my car and hooked with drag radials with 20-23 psi
Old 11-12-2007, 04:44 PM
With the IRS on Corvettes my suspension options are very limited.
Old 11-12-2007, 05:21 PM
Is the car lowered?
Stock height..
Intersecting point??? educate me..
Old 11-12-2007, 05:40 PM
01'WS6's Avatar
Originally Posted by Dr.Accumulator
Stock height..
I dont think thats stock height. That damn thing is on the ground!
Old 11-12-2007, 06:40 PM
NJSPDER's Avatar
i would take care of the wheel hop issue first. what is your current suspension set up? all you really need are a few bolt ons to solve 99% of wheel hop issues. #1 a good torque arm, #2 adjustable lower control arms, #3 LCA relo brackets. i doubt running an 18inch rim is helping your cause much either.
what software are you using for your data logging/tuning? if you don't have anything yet i woudl suggest HPTuners. you can log your runs and see exactly where the issues are occuring and make adjustments between passes.
Old 11-12-2007, 07:03 PM
01'WS6's Avatar
99 FRC 6speed
Old 11-12-2007, 10:57 PM
When the new diff went in it was returned to stock height
Old 11-13-2007, 09:32 AM
Not applicable on corvettes..
next track day ill have some logs to post..and some better ideas on KR
Old 11-13-2007, 04:19 PM
Shoaf85's Avatar
Had a similiar problem with my Cobra, my fix was to get rid of the drag radials and get some et streets. That eliminated all wheel hop! I believe the problem will be within the tires, an 18" drag radial has very little sidewall for flex so I would recommend a smaller diameter wheel and some stickier/bias ply tires!
Old 11-13-2007, 08:25 PM
01bad ss's Avatar
Had similar problem and went from 15" BFG drag radial to Mickey Thompson drag radial running at 15psi and wheel hop went away.
Old 11-13-2007, 08:28 PM
You didnt change anything else..like suspension wise? Just ET streets? BFG DR suck that bad?
Old 11-13-2007, 10:04 PM
racerrob333's Avatar
I put qa1 on the rear and a 90 10 shocks on the front works good for me and i run slicks and drag radials
Old 11-13-2007, 10:07 PM
calongo_SS's Avatar
I would be more worried about the trap speed than anything. That car is not putting anywhere near 600 hp to the wheels @ 118 mph. My 3700 lb pig trapped 126 with an auto with less power. Sure the suspension & tires will drop your et, but it's not gonna do much of anything to your trap speed.
Old 11-13-2007, 10:17 PM
01'WS6's Avatar
