Kooks headers in, PICS!!!
I got my kooks long tube headers in for my 2000 Trans Am. They have(EDIT) 1 3/4 inch to 1 7/8 inch stepped primaries with a 3 inch slip on collector, made out of stainless steel. My favorite pic is of the gasket on the header, the gasket is a perfect match for the header. The total was $1023.66 to my door and was only took 3 weeks, not bad in my opinion. Enjoy the eye candy.
pic 1
pic 2
pic 3
pic 4
pic 5
pic 6
Dan
EDIT: Got the sizes wrong, they are 1 ¾ inch to 1 7/8 inch stepped primaries.
pic 1
pic 2
pic 3
pic 4
pic 5
pic 6
Dan
Re: Kooks headers in, PICS!!!
I just had 1 3/4 Kooks stainless headers and catted y put on my Z. They make top quality headers and Y-pipes. Check out my before and after polishing pics.
Before
http://xpupload.hpphoto.com/servlet/...1870&size=
After
http://xpupload.hpphoto.com/servlet/...592a&size=
Before
After
N.Y. LS1
WOW, I gotta do that!! Very slick, almost looks coated in the second pick. How much did that run you?
They aren't installed yet, just got them in yesterday, but I will post once they are installed with more pics. I’m planning on getting a x-pipe made for it, again I’ll post pics and what not of that when I am done too.
Dan
P.S. Thanks for the compliments!
EDIT: for clarity
Dan
EDIT: for clarity
N.Y. LS1
The Nevr-Dull and Blue-Magic polish cost less than 15 bucks. I did each header twice with the Nevr-Dull, then did each header twice with the Blue Magic polish. Just keep using fresh pieces of Nevr-Dull and they'll come out awesome.
Dan,
Any install issues? What Y didi you use? Any banging?
NY,
That is some good looking polishing work.
NY,
Dan,
NY,
NY,
Thanks, Steve
I should have mine in about 2 weeks. I'm going to try the same thing but I'll sand with 2000 grit sandpaper before.
Those look sweet! My only questions are about underhood heat and upkeep.
Won't it get really hot under the hood and around the plug wires?
How do you plan on keeping them blingalicious?
As far as the up keep, I'm tossing the air and egr systems and plan on doing the coil relo kit. With these things gone, I'll have plenty of room to hit them with the Nevr-Dull every so often.
I got the same stepped headers as you did. The install was easy for me, but I did have to dissconnect the motormount from the block and jack the drivers side up to get it in. The passenger side slides right in, no problems at all. Their ORP is great quality, even crush the drivers side pipe a bit for more clearance. I did have to modify the I-pipe from the cat back though because it didn't line up with the y-pipe, don't know if it had anything to do with the fact I had them make it a 3.5" Y or not though. My ORP does come real close to the drivers side floor board as well, just like my FLP's and TTS's did. I think if you polish them, it'll look good till you start the car and they get hot, then they discolor, don't know if you can polish that out or not. I have some Pics of the headers and ORP I could post up later if anyone is interested...
Dan
Dan
