What am I doing wrong? (LS2 into 67 Firebird)
Old 11-16-2007, 08:48 PM
ehirst83's Avatar
Default What am I doing wrong? (LS2 into 67 Firebird)
I got my motor sat in the engine bay but can't get the motor mounts to line up w/o the pass. head hitting the fire wall. I am using factory BBC pedestool mounts and GM rubber mounts. Is this not correct for the S&P Adapters I'm using???
Old 11-16-2007, 09:27 PM
cherryelky305's Avatar
Some one correct me if I'm wrong but is'nt there a few types of BBc mounts? namely "tall and narrow" and "short and wide". If thats correct maybe your running the tall ones and need the shorter mounts? just a thought.
Old 11-16-2007, 09:28 PM
Schitzo's Avatar
Im sure the first gen guys will chime in with more info but in the mean time try searching for motor mount plate issues.
Here are two threads that might help
https://ls1tech.com/forums/conversions-swaps/472609-lsx-into-67-69-camaro-basics.html
https://ls1tech.com/forums/showthrea...headers+hooker
Im not sure what pedestals the S&P plates are designed to work with but in my experience, when I did the swap using S&P like plates, the engine did not just drop in and line up. I had to relocate the pedestals as needed.
Old 11-17-2007, 12:25 AM
mjls1's Avatar
If the heater hoses are the only issue with motor, you can relocate them with a big block heater core and box. It will put the heater hoses in the middle of the heater box.
Old 11-18-2007, 07:36 AM
leonpiper69's Avatar
i had big block ones and swapped them out for small block ones, perhaps that is your problem too.
Old 11-19-2007, 12:51 PM
67rsss's Avatar
You should be using the SBC mounts. Also, with the small block heater core, you will have to mod the heater tubes a little. If you have a factory style (Harrison), the tubes are angled towards the pass fender. Pull the core and bend the tubes a little more. If you have a cheap replacement with straight tubes, you need to angle them. May be easier to swap over to the big-block style in that case. We had to bend ours about 20* more to clear.
Old 11-20-2007, 08:43 AM
5150mechanic's Avatar
Big block mounts mounts usually shift the motor to the pass side about an inch for steering box clearance.
Old 11-20-2007, 09:16 AM
andrew69_04's Avatar
i had sbc mounts and used the hooker adapter plates, my heater hoses hit like yours did, i just cut them off, im not gonna drive a 69 camaro in the cold anyways.
Old 11-20-2007, 10:39 AM
pist0lpete's Avatar
I will second the notion that the plates were designed for sbc mounts. Also, don't be afraid to unbolt the frame stands and just bolt them to the motor and drop it in. This will allow you to position the engine exactly where you want it, mark it, then drill new holes to bolt the frame stands down with. Also, on a side note, what intake is that? I have never seen anything like it.
Old 11-21-2007, 01:50 AM
ehirst83's Avatar
thank you for all the help. i'm just going to cut the hoses flush for now then. to answer your question the intake is a custom sheet metal piece fabbed in my buddies shop.
Old 11-21-2007, 09:46 AM
pist0lpete's Avatar
Ah I see I guess since the intake is painted black and so well made it looks like it is made of plastic and thats what had me confused. That is a nice piece though!
Quick Reply: What am I doing wrong? (LS2 into 67 Firebird)
