Daily drivers w/600+ rwhp
Wondering if there are any true "daily drivers" with forced induction and a minimum of 600 rwhp and if they have had any reliability issues. I just wonder if you can truely drive one with that much power for a couple years without any problems.
Mine's a DD and have been in-n-out of shops but that was not due to set-up or stress on drive train and systems but rather due to a poor decision in who I used to do the install.
Yes I have problems with mine. Just recently, the alternator went out, power steering pump and resevoir both had to be replaced because of leaks, rear differential is leaking, and I broke off a compression clamp on my exhaust.
The new list of problems that i never suspect never cease to surprise me
I drive mine at least a couple times week and its been running good. Only problem recently was it threw the belt and blew off some intercooler pipes but those were easy fixes. I made 630.
I made 757 and could DD mine if I wanted. My fuel pump quit once (defective), otherwise its never broke on me. Granted I have relatively few miles but I don't see what would break aside from normal wear and tear, assuming you had the entire car built to handle the power you're making, i.e. the trans, rear, etc.
Holy crap man... what kind of numbers did you make?
And Dave Childress drove his car everyday from what I understand. If rumors are correct, it was his only car for a while. He made 850whp on his 93+Meth setup. Then he made 1000whp on C16!
Also, Nasta TA drove his 9.2 @ 150 F Body over 200 miles a week. I think he ended up making over 1100whp on his race gas tune. Not sure what he made on pump. But probably along the lines of 700whp.
Once you get used to that kind of power, it's kind of hard to go back. I used to drive the SS about half the time (it was only about 550rwhp). After the camaro went down I started putting some more mods on the neon just so it wouldn't be so slow. Now it's faster than the SS was N/A w/cam, headers, etc.. When I get back to the track it should be in the mid 12s @ about 113mph. I am totally missing the camaro, but can't do anything about it right now. If I had the money, I would DD a 600+ hp car and the neon would be for when it was down.
Administrator
That's the beauty of a forced induction car. They can be very
mild at part throttle.
