My new clutch setup 5.5" tilton/quarter master
Old 11-24-2007, 07:10 AM
HioSSilver's Avatar
Default My new clutch setup 5.5" tilton/quarter master
Definitly not for the faint of heart, but man it revs quick.
Old 11-24-2007, 07:44 AM
ls1 joe's Avatar
Looks like our Ace clutch. You will definantly like it
Amber
Old 11-24-2007, 08:34 AM
HioSSilver's Avatar
I've never heard of Ace, but apparently it works for you guy's. Is the gearbox in your car faceplated? Do you the clutch when you shift it? I suprised you are'nt using a heavier clutch/flywheel assembly for a drag car. Mine only weighs 16-17 lbs.
Old 11-24-2007, 09:31 AM
ss1
ss1's Avatar
Nice! I ran a Quartermaster 5.5" triple disc on my racecar, so I know how the engagement feels with one of those suckers. Anybody that runs a Spec 5 or any other heavy duty clutch and thinks those engage hard have no idea!
What type of racing are you using the clutch for?
Old 11-24-2007, 10:09 AM
HioSSilver's Avatar
It's a street car.
Old 11-24-2007, 10:26 AM
ss1
ss1's Avatar
Haha...street racing?
All I can say is....WOW!
Old 11-24-2007, 11:46 AM
HioSSilver's Avatar
I was getting tired of the week after market pressure plates making the clutch pedal go away at high rpm's. I think that problem has been aleviated. the gearbox is also face plated
Old 11-24-2007, 08:20 PM
ls1 joe's Avatar
Mine is faceplated and I don't use the clutch on the shift. My cluch pressure plate and flywheel weight 22lbs. The heavy flywheel thing only helps when you can't adjust the clutch. I can adjust the base pressure along with the centrifical counter weight.
Old 11-24-2007, 09:36 PM
HioSSilver's Avatar
How long will the tranny last with out using the clutch? Do you breayh the throttle or just yank the shifter? Which ace option do you use?
Old 11-25-2007, 09:19 AM
ls1 joe's Avatar
My tranny has lasted for a lot of passes, the slipper clutch helps with the shock load on the tranny. The clutch I have is the same one that the prostock cars use. It is 6.25 inches in diameter, and has 3 discs. You will not be able to shift that clutch clutchless, as it has too much clamp load. If you try and shift it without the clutch it will break the lugs off of the gears.
Old 11-25-2007, 05:29 PM
ss1
ss1's Avatar
HioSSilver, have you driven it yet? I'm curious...
Old 11-25-2007, 06:32 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
This is an interesting setup. Looks odd too boot when you compare it to a normal clutch. Want to give out any details of the combo it'll be pushing?
Old 11-25-2007, 07:15 PM
stevieturbo's Avatar
Odd setup for a road car.
I would imagine it wont last long, and be horrible to drive with. I can only guess you must be pushing some serious rpm's to feel the need to use such a clutch ?
As there any fear of that flywheel/ring gear holder disintegrating at high rpm ? Looks quite flimsy ?
Old 01-23-2008, 11:03 PM
will62085's Avatar
updates? how does it run? Im looking at a tilton 7.25 tripple clutch for my new 8k rpm setup and i want some feedback on these types of clutches
Old 01-30-2009, 06:37 AM
HioSSilver's Avatar
10k later everything is still alive with clutchless shifting under full throtttle conditions...... and my gf loves driving it.
Old 01-30-2009, 07:30 AM
ss1
ss1's Avatar
I don't get it, seriously...
When I drove one it was like an on/off switch. Mine was a Quartermaster, and yours is a Tilton of course. I really can't see there being much of a difference though.
Can you slip it at all from a stop? Is there much throw in the clutch pedal?
Old 01-30-2009, 07:37 AM
LS1crazy01's Avatar
Is that a quarter master slave cylinder?
Old 01-30-2009, 07:44 AM
Throw should be the same. But I'd agree...such a small diameter clutch must be horrible to drive with in terms of stop start.
Also, torque carrying ability from such a small diamter must be a lot lower than an equivalent larger diamter clutch for any given clamp pressure. So I assume these clutches are pretty heavy ??
I'll stick with my Tex....
Old 01-30-2009, 09:40 AM
ss1
ss1's Avatar
It looks like a Quartermaster Tri-Lite throwout bearing, but I could be wrong.
Actually Stevie, the throw needed to disengage these clutches is minimal. Manufacturers recommend installing a pedal stop to keep from pushing the fingers in too far because it can damage the clutch. With a 5.5" Quartermaster triple disc clutch and 3/4" master cylinder, it only took about 2" of pedal movement to fully disengage the clutch.
Old 01-30-2009, 03:15 PM
NemeSS's Avatar
is the flexplate stock?
looks like a stock plate,
so does the car runs 9's n/a? or better
Quick Reply: My new clutch setup 5.5" tilton/quarter master
