Stock crank and 1200 hp?
Old 11-27-2007, 08:04 AM
camaroandreas's Avatar
Default Stock crank and 1200 hp?
Anyone tested it with 1200hp and 7000 rpm?
Old 11-27-2007, 08:21 AM
MIGHTYMOUSE's Avatar
i am something like that, my limiter is at 7200 though i normally shift out around 65
earlier this season i was running out on the limiter before shifting to OD like i do now
Old 11-27-2007, 08:32 AM
Sounds good, it´s a LQ9 stock crank..
Old 11-27-2007, 10:35 AM
y2khawk's Avatar
most of the stock cranks are the same casting, sans LS7, with different final machining.
As for power level, been there done that. Many have
Personally, i shifted mine about 8k RPM with power around 1400 crank HP.
Old 11-27-2007, 11:12 AM
Speed's Avatar
just to confirm, this was on a stock crank?
Old 11-27-2007, 11:13 AM
y2khawk's Avatar
yes, like 3 or 4 years ago
171 MPH at ~3300 LBS
Old 11-27-2007, 11:15 AM
Speed's Avatar
I knew you had a hot setup, just didn't know much about it. Makes me feel a lot better about my measly 800hp goals.
Old 11-27-2007, 01:14 PM
NA$TY-TA's Avatar
same here. Stock crank and 1100rwhp spinning to about 7K. Where ever Y2KHawk set the rev lim LOL.
Kyle
Old 11-27-2007, 01:32 PM
Sounds great, thanks !
I will post a thread soon on my Camaro -69 build with a Bullseyepower S480
Old 11-27-2007, 02:32 PM
TwnTrboCE's Avatar
Stock LS1 crank- 8.50's @ 170 @ 3700lbs, shifting at 7800.
Stock LS7 crank- 7.91 @ 177 @ 3450lbs, shifting at 7400...So far
Old 11-27-2007, 02:39 PM
LS1RedZ's Avatar
Damn that makes me feel better!!
Old 11-27-2007, 03:29 PM
y2khawk's Avatar
i guess you're the crazy ****** now
Old 11-27-2007, 03:45 PM
Speed's Avatar
I think you are all crazy *******!
I'm a fan
Old 11-27-2007, 03:46 PM
y2khawk's Avatar
I'm a fan
you ain't seen nothin yet
Old 11-27-2007, 04:00 PM
DanZ28's Avatar
Kyle
Kyle, ddi you mention somewhere about yours starting to flex? I' don't know, I've read so much I don't know who did what anymore, lol.
Dan
Old 11-27-2007, 05:36 PM
cbra-klla's Avatar
why does anyone even bother with aftermarkert cranks then???
Old 11-27-2007, 05:47 PM
Andy02Z's Avatar
Stroker, peace of mind.
Old 11-27-2007, 05:48 PM
67Firebird455's Avatar
To increase stroke from 3.622.
Old 11-27-2007, 06:16 PM
NA$TY-TA's Avatar
Dan
My stocker was reused in 3 motors and in the 2nd to the last it was scored some. Harlan can atest to that. He pulled the mains last time. When the motor was rebuilt the crank needed I be cut some and I'm not sure ifnit was nitrated again and if that made it weaker. Not sure. All I know is it was flexing. I was stillnusing stock main caps. This time they will be billit main caps and a forged crank more for cubes then anything. I'd use one and not be scared.
Kyle
Oh yeah. Show off Mike.
Old 11-27-2007, 06:27 PM
Wonderbread's Avatar
From what I hear and have experienced the 5.7 cranks have hollow rod journals and are a little harder to balance without adding mallory metal. The 6.0 Cranks have solid rod journals and can be drilled for balancing purposes. This is all assuming after market rods and pistons and I guess can depend on the bob weight.
Im not doubting any of you guys, the numbers you put up speak for themselves and are insane!! . Just figured I would throw my .02 in.
Quick Reply: Stock crank and 1200 hp?
