240 SX swap questions.
Old 11-28-2007, 05:21 AM
Spoolin's Avatar
Default 240 SX swap questions.
I just bought a 1995 240 sx and have a few ideas running through my head and wanted to get some feed back from you guys.
I plan on putting in a 5.3L LM7 that came out of my truck, gonna bore it out to 5.7 and try to make it a strong high compression N/A set-up as I can.
Questions are...
1) Motor plates, what drawbacks would using those have over regular motor mounts? Advantages?
2) Saw from a previous build that I'm looking at 56/44 weight distribution on the car if I do a direct swap. Anyone have differnent weight distribution numbers and if so how did you achieve them?
3) Transmission. Either gonna bolt up a T-56 or if I can I'd like to take a transaxle out of a vette and do that. Anyone ever do that before and suggestions? (As a plus if I ever go turbo I have plenty of room in the trans tunnel )
4) Dry sump...worth it if it's just gonna be a street car taken to road courses occasionally?
Thanks for the help, should be getting my car soon so I will start a thread once I get it and rip into it.
Old 11-28-2007, 12:40 PM
cherryelky305's Avatar
the only trans-axle swap I can think of is the civic. Thats the only one Ive seen using a whole corvette powertrain.
https://ls1tech.com/forums/conversions-swaps/730443-newbie-ls1-but-not-your-typical-car.html
I dont know how much help that thread is gonna be since he mostly just cut the civic to fit onto the corvette stuff, but gives you an idea i guess. good luck.
Old 11-28-2007, 02:58 PM
Spoolin's Avatar
Lol, yeah I saw that thread a while ago. He did an incredible job with it. Unfortunetly I don't have the whole chassis and powertrain to do what he did and honestly I don't think I want to do that...looks like a nightmare! Lol
Old 11-30-2007, 01:32 AM
Spoolin's Avatar
bumpity bumpity? and suggestions?
Old 12-07-2007, 08:16 PM
GTOpowered240sx's Avatar
Is this going to be a street car, or what are your plans for it?
Old 12-07-2007, 10:40 PM
Kamin's Avatar
1) pointless on a street car
2) weight distribution is the most worthless fact of a car ever. dont worry about it. the car will handle fine.
3) why bother with the vette rear, a t56 fits and works, just use that
4) worthless on a street car
Old 12-08-2007, 12:30 AM
Spoolin's Avatar
It's gonna spend time as a DD and also at road courses a few times a year, not competitively but don't want it to handle so bad it spins out at every turn. But mostly street and occasional track days.
Old 12-08-2007, 12:31 AM
Spoolin's Avatar
Ok then...motor plates are out.
And Dry sump is out.
Cool
Old 12-08-2007, 06:40 AM
mikespeed95's Avatar
what does motor plates mean?
run a fbody t56
run an accusump.
do lots of burnouts.
Old 12-08-2007, 01:52 PM
Spoolin's Avatar
run a fbody t56
run an accusump.
They are an alternative mounting method to motor mounts. Same thing that you were asking about in this thread here
https://ls1tech.com/forums/conversions-swaps/732970-nissan-240sx-s14-modded-gto-pan-tons-pics.html
From what I understand they are good for strip and racing applications because they provide the better support(depending on how they are used) and also act as strut braces/bar and help reinforce the chassis in the process but the drawbacks are NVH which sucks for street driving.
Old 12-08-2007, 04:39 PM
yah i moseyed on over to that thread and checked it out, thats a really cool idea the more i think about it. id like to see why more people arent doing it.
Old 12-08-2007, 07:49 PM
Spoolin's Avatar
Yeah, I was thinking how it would help with some clearance issues as well as the other benefits.
Old 12-08-2007, 08:19 PM
LS240sx's Avatar
Spoolin I told you I can help you with all of your swap questions. You dont have to make 12 different threads.
Old 12-08-2007, 08:34 PM
Spoolin's Avatar
LOL, well I think 12 threads is a little excessive! Lol
But thanks bro!
I started this one before my car showed up at my house, started the other one once I had it in my possesion!
Maybe a mod could combine the two!?!
Quick Reply: 240 SX swap questions.
