Location for WG
Old 12-01-2007, 10:36 PM
71chevellels1's Avatar
Default Location for WG
In the process of building a custom turbo set up. Doing the merge was a pain in the @ss. I was wondering if i could just cut a hole on 1 of the pipes really close to the merge it would basically be in the merge but only welded on one pipe. THanks
Old 12-01-2007, 11:05 PM
70Stang's Avatar
Pictures would help but what you are describing is do able but it is critical that the flow is a priority.
Old 12-01-2007, 11:18 PM
Dont laugh. Heres a extremely detailed drawing. hahha
http://www.putfile.com/pic.php?img=7205044
Old 12-01-2007, 11:28 PM
70Stang's Avatar
Awesome technical drawing, did you use a cad program or are you just that good?!
What is the turbo setup? Are you going to be running a small turbo with low boost? or a big turbo and big boost?
If wastegate control is important (like, you have a smallish turbo but want to keep boost down on a stockish block) I would put on gate on each side of the merge...see technical drawing 1 or if room is an issue, see tech 2.
Technical drawing 3 would work if you have a large turbo and a large gate (either to control it to low boost, or a high boost setup)
What gate/turbo/motor are you using?
Old 12-02-2007, 12:06 AM
Im running a t4 76mm turbo. 9#s ls1 with stock bottom end, 6.0 heads w/ ls6 cam. The problem is i dont want to cut a hole over where i welded the two pipes togthere. Heres another pro picture of how mine is welded. Will it work how i did it?
http://www.putfile.com/pic.php?img=7205151
Old 12-02-2007, 12:09 AM
Heres a pic of the set up.
http://www.putfile.com/pic.php?img=7192271
Sorry 44mm tial
Old 12-02-2007, 12:46 AM
Broke EF's Avatar
You shouldnt have the wastegate off to one side like that, it will lead to boost creep.
Sean
Old 12-02-2007, 12:55 AM
Gordon0652's Avatar
Try doing something like this.
Kind of crapy design, but it only took a few.
Hope that helps!
Old 12-02-2007, 01:22 AM
IMD
IMD's Avatar
it always best to NOT put the wastegate at a 90 degree angle from the pipe its attatching to.
Old 12-02-2007, 01:46 AM
black98ws6ta's Avatar
Yeah, if possible you want to place it so the exhaust flows freely right into the pipe against the bottom of the valve.
Old 12-02-2007, 02:36 AM
Ya i know that is normally the way to place it but i thought it might work also if i mounted it on one pipe but low enough on the merge like this picture.
http://www.putfile.com/pic.php?img=7205418
It seems like it would be low enough to manage both sides.
Old 12-02-2007, 11:46 AM
Gordon0652's Avatar
Isnt that still 90 degrees. If some one tells me where to put the WG on that drawing i will draw it up again.
Old 12-02-2007, 11:57 AM
Gordon0652's Avatar
There, no longer at 90 degrees, but there is a lot more work involved, but it would look sweet if its done right!
Old 12-02-2007, 05:42 PM
Gordon0652's Avatar
Anyone figure out where it should go?
Old 12-02-2007, 08:18 PM
MECHAM's Avatar
daily driven street car runs 9.0x has his piping like this
http://www.richmondperformancemuscle.../original.aspx
tti race kit
http://inlinethumb18.webshots.com/31...600x600Q85.jpg
it'll get the job done.
OFI
http://i10.photobucket.com/albums/a1...ure1111002.jpg
im no turbo expert by any means..but looking at kit builders..they all have it like how gordon 1st CAD drawings
Old 12-02-2007, 11:13 PM
ls1_chevelle's Avatar
On parish's fairmont he is running his gate on the drivers side bank only... I was talking to him and he mentioned he is having no problems....?
Old 12-02-2007, 11:29 PM
MECHAM's Avatar
i dont think it really matters...another kit like you described but for a moostang.
Old 12-03-2007, 01:54 AM
Yes, the pitcure above is how i want to mount my WG. Will that lead to problems?
Old 12-03-2007, 10:06 AM
FieroZ34's Avatar
No that will work fine. Here's mine, I don't anticipate any problems at all:
Old 12-03-2007, 10:34 AM
70Stang's Avatar
Wastegate placement on high boost cars (Like parish's truck) is not nearly as important as it is on a stock motored car that needs a low boost with good control.
The Tial 44mm is a great gate and can flow enough, even in a bad location, to be ok. I would put wastegate placement at the top of my list of priorities.
Yes, centered in the merge at a 90 will be fine.
Quick Reply: Location for WG
