Stupid AC Delco
Stupid AC Delco
Was putting the car up for winter last Friday and went to take out the battery. No biggie, pull the negative no prob. Get to the positive and the sucker wouldn't let go. On top of that my wrench kept slipping on the post. So, i get a pair of pilers to get a bit more leverage and pop goes the post out of the battery. Son of a.... turns out the battery was cracked and had been leaking slowly for a little while and the acid froze it up. Crap...
I get the battery out of the car as fast as possible as it is leaking acid everywhere. It's trashed now, and I'll be replacing it with an optima red top come April.
My question in, my positive battery lead is now all boogered up. The post is rounded off, its got dried up acid on it and it still has a chunk of batter plastic on the back end of it. How hard is it to change the whole cable? I'd rather just start fresh. Anyone done this? The negative wouldn't be too bad, but the positive runs all over the place. Any advice?
Make sure you get all the spilled acid neutralized, friend of mine had two separate delcos leak from the positive terminal - I'd pull the battery tray/coolant tank and make sure you get it all.
You have to plan on a good hour or two, it runs to the starter and the alternator, but it's the right way to do it.
mine are screwed up also, but im changing mine to these 2 gauge monsters:
My cheap *** Auto Zone battery hasn't leaked a drop.
Re'
