shortblock question...
Old 12-06-2007, 11:49 AM
Soul TKR's Avatar
Default shortblock question...
guys i'm thinking I might just get a new/low mileage shortblock instead of forging/rebuilding my current LS1.... i'm looking at the LS2 shortblocks...
my question is... what's the difference pro's/con's between an aluminum and an iron shortblock?
i know there's a weight difference... not sure how much... but anything else?
now I just gotta find one for a budget build...
Old 12-06-2007, 05:24 PM
santiago's Avatar
i went with an iron 408.....budget.
Old 12-06-2007, 06:01 PM
sroach20's Avatar
i know it around 70lbs between an ls1 and an lq4/lq9. id say it depends on if you want forged and what you want to spend on the block. you can find used iron blocks all over, ls2 block will run a bit more.
Old 12-07-2007, 08:53 AM
radkon's Avatar
Cost, weight and ability to overbore (the iron block can be bored out more), some say strength but I've seen stock blocks take some serious power.
Old 12-07-2007, 09:07 AM
2000KnightRider's Avatar
If I dont solve the knocking problem in my engine, I'm going to pull the trigger and probably just buy this:
http://www.sdparts.com/product/SDLS6...kAssembly.aspx
Old 12-07-2007, 03:21 PM
Soul TKR's Avatar
that's a good find...
i've been looking at these as well...
https://ls1tech.com/forums/showthrea...6&page=1&pp=20
Old 12-07-2007, 03:40 PM
Dang thats a sweet find there. My 243 heads, Torquer2 cam should mate up to the 370 short block correct?
Old 12-07-2007, 04:30 PM
TheLS1Kid's Avatar
Thats cool if you want FI because those -25cc pistons.
-25cc pistons on an N/A setup would be ****. Not enough compression.
Do they offer a shortblock more for an N/A setup?
Old 12-07-2007, 04:34 PM
Soul TKR's Avatar
yea i would be N/A.... not sure if they offer a different one...
Old 12-07-2007, 04:43 PM
Soul TKR's Avatar
so is the weight difference on an iron really gonna hender you that much?
Old 12-07-2007, 05:00 PM
sroach20's Avatar
i went with an lq4 because it was $1000 and only had 9,000 miles on it. i have no regrets. if i ever decide to go fi i will feel better knowing its an iron block, even though it wouldnt make much difference if a rod let loose. average price of a good condition ls1 was $1000 and up, with 70,000 miles or more. i feel real good about it because i can run l92 heads instead of being stuck with overpriced aftermarket heads. the iron blocks are cheap and everywhere.
Old 12-07-2007, 05:28 PM
Soul TKR's Avatar
good to know thanks!
