How much can i boost? (sts)
Old 12-08-2007, 10:44 PM
1fastz's Avatar
Default How much can i boost? (sts)
I am in the process of buying a sts kit and i was wondering how much boost my motor will be able to handle? It is not completely forged. The motor has an ls6 crank, ls6 connecting rods with ARP bolts, and has speed pro forged pistons. I understand that the weakest part of the ls1 motor seems to be the stock pistons. I have read that the connecting rods with ARP bolts are good up to 500rwhp and that the stock crank can handle up to a 600rwhp beating, but the stock pistons are crap. So i was wondering how much boost my motor can handle being that i will have upgraded the injectors and fuel pump as well. Also, how much power do you think i can make? I have the following mods in sig.
Old 12-08-2007, 11:11 PM
RearMountKing's Avatar
I think the rods and pistons are pretty good til about 500... Rod Bolts will help with higher RPM's... But the Rods themselves are still going to be pretty weak..
The pistons you have should be good for 600+...
I would make sure you get an intercooler or Meth... IAT's on a stock STS system, will be a killer for your motor...
Old 12-09-2007, 09:38 AM
NYSS Guy's Avatar
Is it stock compression? By the way, you may want to get rid of the LT's. Stock manifolds will actually help reduce lag. I wouldn't be surprised, if you are stock compression, to hit upper 400's rwhp with about 8 psi. It will be nice with the 3500 stall too.
Old 12-10-2007, 12:02 AM
MonochromeSS's Avatar
My car has long tubes and with my 3000 Vig spooling is not an issue. If your cam has a smallish LSA it will hurt your power some. But with 6 psi my car put down 436 hp on a stock 347 no ic no meth. 8 psi should be high 400s. Without meth or an IC 7-8 psi is the limit to be safe.
Stock crank is good for quite a bit more than 600 hp.
Old 12-10-2007, 03:47 PM
quik01ss's Avatar
10 psi lol but though your stock manifolds on with an off road y pipe and then youll need an i pipe for the turbo. also that cam make sure it can run for a fi setup..check my sig nothing big done to the motor ...yet
Old 12-10-2007, 04:01 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Stock crank should be good for at least 900rwhp. I'll bet you could go 600rwhp with your internals as long as you have an intercooler or meth (or both)...
1fastz's Avatar
Originally Posted by quik01ss
10 psi lol
10 psi then? How much power should that put me too? and why is it funny? lol
oh yea, i changed my sig, it now displays the specs of the cam. Its basically a 222/224 but on a 115lsa. I wanted my motor to be cali smog friendly.
Old 12-10-2007, 04:04 PM
quik01ss's Avatar
its funny for me because in my case im waiting for my motor to f up or my rear there other things also to worry about other than jus your bottom end
Old 12-10-2007, 04:08 PM
quik01ss's Avatar
https://ls1tech.com/forums/forced-induction/817069-stock-block-13psi-7250rpm-pics.html mmmhhmmm
Old 12-10-2007, 04:18 PM
1fastz's Avatar
damn.... im staying away from 13lbs then, lol. better make it 10psi max.....
Old 12-13-2007, 12:45 AM
1fastz's Avatar
has anybody else ran 13lbs tho??
Quick Reply: How much can i boost? (sts)
