Which gears do you suggest?
Old 12-27-2007, 03:44 PM
sdimess84's Avatar
Default Which gears do you suggest?
Im thinking about upgrading my 10 bolt in my s10. I have a cammed 5.3L, 4l80e with 342 gears. Im going to put a zexel unit in it. Should I run 3.73 or 4.10 gears? This is my DD and I drive about 50 miles a day for work. What do yall suggest?
Old 12-27-2007, 03:53 PM
styoung's Avatar
need some cam specs.
Old 12-27-2007, 03:54 PM
SS1156's Avatar
What size tires do you have?
Old 12-27-2007, 09:09 PM
sdimess84's Avatar
I am running 275/40/17. What specs do you need?
Old 12-27-2007, 09:11 PM
venomhp's Avatar
is it mostly highway or city streets, and basically its what you want, if you want it for a good highway cruiser with a little bit better low-end power then go with the 3:73's. if you can sacrafice a few more RPMs at highway speed (worse mileage) and want a lot better low end then definately go with the 4:10's
Old 12-28-2007, 10:22 AM
Jawsgear's Avatar
What final drive ratio do you have on the transmission?
Jeff
Old 01-15-2008, 11:53 AM
sdimess84's Avatar
the gear ratio of the trans are:
1st: 2.48
2nd: 1.48
3rd: 1
4th(OD): .75
Any other info needed?
Old 01-15-2008, 03:45 PM
Jawsgear's Avatar
1st: 2.48
2nd: 1.48
3rd: 1
4th(OD): .75
3.73 Ratio with that combination. It should put you at about 2400rpms at 70mph.
Jeff
Old 01-23-2008, 04:37 PM
sdimess84's Avatar
Thanks for the help! I hoping the 3.73 will help me out off the line a little better. That big trans slowed me down a little
