Flywheel/ new clutch question
Old 12-28-2007, 05:00 PM
Mac93's Avatar
Default Flywheel/ new clutch question
Hi I am doing a clutch in my '00 Z28 and I think I might have a problem. See my old RAM HD wore a groove in my flywheel so when it was resurfaced, they had to take off 50 thousandths. I've heard that I wont need a flywheel shim. Should I just use the slave spacer? Will that work?
Old 12-28-2007, 09:44 PM
Mac93's Avatar
Need to know this soon please.
Old 12-29-2007, 06:00 PM
Mac93's Avatar
Old 12-30-2007, 04:44 PM
Mac93's Avatar
Can someone please answer me, my clutch comes tomorrow and I want to get it together as soon as I can. New clutch is a RAM Powergrip HD.
Old 12-30-2007, 05:09 PM
BarneyMobile's Avatar
What about just getting a new flywheel. I kno if you put to big of a slave spacer/shim then your pedal gonna be way high.
Old 12-31-2007, 04:14 PM
Mac93's Avatar
Any others?
Old 01-01-2008, 08:56 PM
Mac93's Avatar
85 views and noone knows?
Old 01-02-2008, 11:14 AM
walter1234's Avatar
You should have the flywheel replaced. GM recommends the flywheel to be replaced for every clutch change out.
Old 01-02-2008, 11:36 AM
Mac93's Avatar
Its a Fidanza flywheel if that makes any difference and it's the first time its been resurfaced.
Old 01-02-2008, 11:38 AM
Benner's Avatar
50 thousandths is alot to have to cut off. I'd replace the flywheel if it were me.
Old 01-02-2008, 01:15 PM
SPEC-01's Avatar
.050 is a large amount of material and will have a major effect on geometry. I would install a new unit...of course most will assume that this suggestion is made in hopes of selling you another flywheel...I would just hate to see you have to pull it all apart again only to buy a new one later!
