Drop eng to add mods?
Old 12-28-2007, 11:06 PM
geovett's Avatar
Question Drop eng to add mods?
i know this q..has been asked many times, is it better to drop Ls1 o1z to add heads, cam, oil pump, timing chain, headers,spark plug wires, plugs, thanx for info.......:confused :
Old 12-28-2007, 11:31 PM
venomhp's Avatar
yea itd be easier to do it when its out
Old 12-29-2007, 01:16 AM
LastBlack02SS's Avatar
Sure if you had it out it'd be easier than in, but completely unnecessary with the standard bolt ons, heads, and what not.
Old 12-29-2007, 08:29 PM
EastTnZ28's Avatar
Its pretty easy to drop if you got a place to do it. If it has alot of miles I would do a standard rebuild. Forged Rods, Pistons, Crank, Bore and Stroke. Just kidding. I find when i have my motor out I do alot of stuff I hadn't planned to do. But seriously id put ARP rod bolts in. Just drop it. If nothing else it would be a learning experience. Good luck.
Old 12-30-2007, 02:24 AM
waldershrek's Avatar
Yeah it would be easier but it isn't that much harder to do it with the motor in the car. For the extra effort you would spend doing the R & I on the motor you could have spent that time doing the actual mods.
Old 12-30-2007, 02:33 AM
bryan04h's Avatar
with it out you can do all that, you can also install a lightened flywheel, new clutch, and clean up the engine bay while it is out....but like it has been said, unless you need the engine out for a bigger reason(ie replacing anything in the block)..i wouldn't recommend it
Old 12-30-2007, 05:53 AM
billyb's Avatar
Default these guy's remove it
http://www.tick-performance.com/fbodyprices/ and a good price too!
Old 12-31-2007, 10:22 PM
jsteele90's Avatar
too much work. unless you really wanna drop it id just leave it in and work around it.
Old 12-31-2007, 10:44 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I put the H/C on my car while working in the grass
Old 01-01-2008, 02:28 AM
bryan04h's Avatar
^^^you wanna put my h/c in i see your from shady j too!!
Old 01-01-2008, 04:39 AM
slowjoe99's Avatar
all that can be done with the motor in
Old 01-01-2008, 06:04 AM
Z28/2002's Avatar
Was it your car that Sean put the exhaust on and it kept fell off? But yeah hit me up when you get back and I'll lend a hand
Old 01-01-2008, 10:41 PM
silverTA2002's Avatar
We did my H/C swap without dropping the engine with no problem.
Why add extra work? The only "difficult" bolts are the header bolts and the engine would have to be in place to attach them anyways.
Old 01-03-2008, 07:18 PM
geovett's Avatar
Cool
hey Great stuff, thanx i wasn't 2 sure because i'm installing a verter, yank4k the car has only 35k miles so i think motor stays in.............
