a little help ls7 clutch installed
Old 01-04-2008, 05:26 PM
ssblackss00's Avatar
Default a little help ls7 clutch installed
Ok I had a ls7 clutch kit, new slave 01+, new master, and drill mod installed in my 2000 SS and it is very notchy now and at a dead stop with the car running it will not go into 2 3 or 5th gear but it will when the car is moving. and it is very hard to get it to reverse I have to smack it in, if I try and push it in even with both hands it will not go. Will this go away after a while or does it need the be bleed. Any help would be GREAT
Old 01-04-2008, 08:50 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Bleed it first
Old 01-04-2008, 10:07 PM
camarojunky74's Avatar
sounds like your clutch is not disengagin all the way, like this guy said try bleeding it first, if no luck, post again
Old 01-05-2008, 08:33 AM
SSDoubleK's Avatar
Gotta make sure you bleed the system alot, also did you invest in one of those great remote bleeders? I will not do a install without one. Also with the LS7 clutch, did you install a shim?
Old 01-05-2008, 10:20 AM
no shim but im going to bleed it right now
Old 01-05-2008, 11:35 AM
TheLS1Kid's Avatar
Yea try bleeding it more.
Nice avatar Z28/2002!
Old 01-05-2008, 07:17 PM
o2camaross's Avatar
^^^I was thinking the same thing^^^^
Old 01-05-2008, 07:34 PM
no title here
skyhighsami's Avatar
Z28/2002 do you have any more pics of the person in your avatar? WOW!!
Old 01-05-2008, 09:00 PM
Ok well bleed it manually with to of us one under and the other at the pedal and no air cam out what so ever so im going to get a mityvac in the morning unless anyone thinks other wise?
Old 01-07-2008, 07:31 PM
ok well i figured the problem out the the reverse lock out was plugged into the the skip shift could this do any damage
Old 01-07-2008, 07:37 PM
i cant imagine unless you drove it like this for a long time
Old 01-07-2008, 08:39 PM
hundred and 124.3 miles to be exact so what you think?
Old 01-07-2008, 11:24 PM
i think you will be fine, if your paranoid change your trans oil, that should take any guilt away for me
Old 01-08-2008, 01:09 PM
Z28/2002's Avatar
Yeah but I'm not sharing.
She is an old gf of mine
