carbon fiber valve covers
The carbon fiber valve covers part #
SDL002VC
that scoggen dicky sells look real trick. EPP just installed them on there blown orange camaro , they look awesome
but i wanted to find out if they would be good on a street car, how well they fit, seal, and can i mount my stock coil bracket to them.
thanks for your help
SDL002VC
We like them alot, no issues with sealing. They are a really sturdy peice and i definatly would not hesitate to run them, you might consider relocating the coils so you can show them off.
You can get the coil brackets from SDPC that bolt right onto these.
Nice , how much for the coil brackets Jake@EPP? , also Do i need longer wires or anything else , I am running brand new Taylor Thunder volts ? and i like those wires , they are the best.
Did they come with oil fill cap and will the PCV system all go together , my car is Procharged and i run a ANW catch can
thank you for your help
SCPC also sells ones that say chevrolet on the top they are nice. I ordered them, should be here Tuesday. If you wanna see some, search "aftermarket valve covers" theres a entire thread with pictures of all different ones.
Im not 100% sure the wires will work, we used truck wires as they are a little bit longer and we had a bit of slack.
It has a oil fill hole with cap, and a 3/8s barb for the breather, it is not in the same place so you will have to figure something out for it.
I would say they are marginally taller, not sure on a exact. They are defiantly a show stopper valve cover, and when used with the msd coil packs like we had setup, they just look plain awesome.
