Ok the aftermarket is so dizzying I dont know where to start what are gimmicks?
Old 01-14-2008, 06:00 AM
onebadazzls1ta's Avatar
Default Ok the aftermarket is so dizzying I dont know where to start what are gimmicks?
Ok has with every aftermarket some gadgets and gizmos dont do j/s, for instance I believe that the tps enhancer doesnt work if I recall. And on the g/p's the coils are just fine even when modded the coils put out enough voltage. I just wanna know what i should do mod wise ignition wise, And what I need and what I dont need I'm probabaly gonna need a tune up real quick because I dont know what's been done and what hasnt. The previous owner did a semi good job of keeping track of oil changes and ****. what I mean by tuneup I mean plugs,wires,fuel,oil filter,coils, & pcv valve. The whole reason why I'm asking is because I wanna go semi high performance this time. Anyways any opnions from experts and newbies would be appreciated. Oh do they make taylor thunderbolt 10.5's for our cars? I know it's probabaly excessive for a stock motor but I wanna try to squeeze has much out of it has possible without diggin into the motor. Thanks in advance
Matt
Old 01-14-2008, 10:45 AM
teke184's Avatar
year and specifics on the car would help.
coils are fine even on HIGH hp levels
tps booster is useless
hypertech (and most handhelds) programmers are crap compared to a good dyno or street tune
turbonator is junk
any aftermarket wires work fine, they are so short on a ls1, that you don't hve to spend $100 on some fancy ones. i like my Taylor spiro-pros for $50. you won't see any more power with $$ wires. same goes for plugs...stick with tried and true...and inexpensive...NGK TR55s. they are $2 each and work just as well as the $10/each plats.
Old 01-14-2008, 11:23 AM
99mongooSS's Avatar
tr55 and some msd wires and walk away from it
Old 01-14-2008, 12:45 PM
RedRallyeZ's Avatar
+1, and do it when you swap headers, because thats about hte only time youll be able to reach them
Old 01-14-2008, 05:48 PM
Thanks guys and the specifics of the car is a 99 ls1 with t tops transam vin code r I believe All stock for now.
Old 01-14-2008, 09:51 PM
so basically all i need is delco wires due to the short distanc?
Old 01-14-2008, 10:09 PM
JScamaro's Avatar
I would get the msd's personally but the stock wires will do fine.
Old 01-15-2008, 06:49 AM
ok thanks any other opnions?
