Coil Relocation
Coil Relocation
So i just finished up my home made coil relocation brackets and i would throw up some pics but i realized that i dont know how to on here
send them to GS96C599@aol.com I'll put them up tomorrow. LABELED PICTURES****************** so I don't miss it!
john
john
i took a flat piece of steal like the ones on the thunder racing kit they just bend up and bolt under the wipers and plastic cowl that way i can remove them without having to try and reach up there here is a pic under the plastic http://i264.photobucket.com/albums/i...e/IMG_0567.jpg http://i264.photobucket.com/albums/i...e/IMG_0568.jpg
looks almost exactly like my TR kit. one thing i did to make removal easier is to only use one bolt per side on the cowl and zip tie the other hole. still solid as a rock.
and if u put [ img] [ /img ] tags without the spaces around the links the pics will show up as images instead of links
i hear ya man its 5 degrees out right now but im finally reconstructing just put the new cam and heads in and noticed that the washers on the head bolts had to be a certain way so i get to fix that tomorrow
