Exciter wire
Old 01-21-2008, 05:22 AM
Restricted User
socmguy's Avatar
Default Exciter wire
I can jump my car off and it'll start and run but as soon as I try to start it the batt/starter just clicks. I've replaced my battery and my alternator. Should I try replacing my exciter wire next? I hear it's the small red wire that goes to the top of the alt. Where does it go from there?
Old 01-21-2008, 07:57 AM
LS1MCSS's Avatar
What kind of car is it?
Old 01-21-2008, 11:48 AM
Restricted User
socmguy's Avatar
2000 Z28
Old 01-21-2008, 12:05 PM
01Z28M6's Avatar
Man, check your connections, especially the grounds. I'm not much help but I want to see how this unfolds. Good luck there.
Old 01-21-2008, 12:10 PM
2001NBMZ28's Avatar
Sounds like the battery to me since it starts and runs after jumping it. I'd have it load tested.
Old 01-21-2008, 01:53 PM
LS1MCSS's Avatar
Jump it and after it starts, use a volt meter to see if the alternator is charging. If it is, then you have either bad battery or bad connection at the cable.
Old 01-21-2008, 02:02 PM
connexion2005's Avatar
Is your starter hanging? Kind of sounds like it is. Whenever this happens crawl underneath and tap the starter with a hammer and have a buddy turn it over and see if it doesn't fire up. If so then you have a bad starter...
Old 01-21-2008, 04:54 PM
Restricted User
socmguy's Avatar
I have an optima red top (less than 1 yr old) load tested @ batteries plus and they say it's a good battery, I just replaced my alternator (160Amp) and I double checked my grounds. How could the starter be messed up if starts when I jump it off. Car just clicks when I try to start it on it's own power. Battery reads 11.2V when I test it w/ the car off. When I jump the car and it's running I have 13.8V. If anyone else can help I would appreciate it!
Old 01-21-2008, 05:23 PM
stevensLS1's Avatar
does your battery guage read lower than normal? i replaced the little fuse in the exciter wire and that fixed my problem
Old 01-21-2008, 05:47 PM
Restricted User
socmguy's Avatar
Yes, it used to read lower than normal so I bought a 160A alt. Now it reads about 13ish on the voltmeter but still is giving me problems. Where is the little fuse located? Near the injectors?
Old 01-21-2008, 06:04 PM
stevensLS1's Avatar
no, its a few inches off the plug of the alternator. the wire flares out just a little but you can tell the difference. ( at least thats how it was on my 00 t.a)
just go to the local parts store and they should have it. hope this helps. id take a picture but my cars in the shop atm.
Old 01-22-2008, 05:32 PM
Restricted User
socmguy's Avatar
anyone have pics?
Old 02-01-2009, 02:44 PM
PI HAT's Avatar
Question
dude..that sucks! Going throught the same thing EXACTLY!!! WTF
Old 02-01-2009, 02:47 PM
WS SIKZ's Avatar
start the car and put a volt meter on positive and negative battary terminals should be charging at 13.8- 14.3
if thats good get a load tester for the battary with the car off put a load on it and see if it dies down after ten seconds
and when you check the alternator rev it a little too to make sure it increases with rpm and is not just stationary
