LQ9 - LS1 interchange able parts?
Old 01-24-2008, 01:23 PM
LS1IMPULSE's Avatar
Default LQ9 - LS1 interchange able parts?
I will be using a 6.0L iron block for a turbo build and cannot find in the searches what parts can (or need to) be used from the LS1? Parts like the oil pan, lifter trays rocker arms etc.
Old 01-24-2008, 02:32 PM
Dumb Ass Vette Moderator
ls1290's Avatar
A LS1 rear cover seal can not be used on a LQ4 block. I learned that one the hard way.
Keith
Old 01-24-2008, 08:43 PM
LS1IMPULSE's Avatar
haha nice, im hopeing everyone can pitch in what they know, and maybe make a sticky out of this topic, with all the people using LQ9 blocks for a turbo motor i was suprised i couldn't find what what parts would and wouldn't work.
Old 01-24-2008, 09:13 PM
HydroStream6's Avatar
I used all the accessories and covers and sensors from my LS1 with my LQ4 block. Heads too of course. Only thing was for the alternator I could only use 2 bolts instead of 3... but it's been that way for 3 years now.
Ohhh and also the LS1 has the oil dipstick provision in the pan, and the iron block has it in the block... you need to do something about that or you'll spit oil all over... I just covered the one in the block and used my GTO pan.
That's about all I can remember though... correct me if I'm wrong.
Old 01-25-2008, 01:30 AM
LS1IMPULSE's Avatar
all these people using iron 6.0 blocks and only 2 people resond with any info?
Old 01-25-2008, 08:05 AM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
Keith
why cant you use the rear cover? i was unaware of this
Old 01-25-2008, 08:52 AM
ls1290's Avatar
You can use the cover, it is the cover seal that is different.
Keith
Old 01-25-2008, 09:22 AM
red83's Avatar
whats the difference in the gasket?
Old 01-25-2008, 10:28 AM
trtturbo's Avatar
pan, p/u tube and windage tray are different. If your putting it in an f-body, you will need to drill and tap a hole for the alternator bracket.
Old 01-25-2008, 11:07 AM
LS1IMPULSE's Avatar
Keith
So the front a rear covers from LS1 can be used on the LQ4 block but not the rear cover seal?
So you used every cover and seal from the ls1? valley cover, front and rear cover, oil pan etc. all of it? what about internals? lifters, lifter trays, rocker arms, rocker arm trays etc.
Ok which pan should i use? im assuming from the other answer the LS1 pan will work but I need to plug the provision in the 6.0l block.
Old 01-25-2008, 11:52 AM
trtturbo's Avatar
if your putting in an f body, then your f body pan. There is no hole to plug. Everything bolts right up. We have done many motors and swaps. Feel free to call me and I will help in anyway I can. 817-703-3750 Billy
Old 04-20-2008, 01:09 AM
jed.only's Avatar
whats different about the seal? and what was used to plug the dipstick provision in the block?
Old 04-20-2008, 07:05 PM
itslow's Avatar
This is only an issue when using a GTO oil pan. Use the same plug as is used in the block on the GTO. Not an issue when using the F-Body oil pan, which puts the dipstick through the boss on the block.
Old 04-20-2008, 08:30 PM
98mysticZ's Avatar
i just swapped everything over used a ls1 rear seal as well... no probs so far
Old 05-20-2008, 05:24 PM
mike s.'s Avatar
Does anyone have input on using an f-body LS1 crank, rods, in an LQ4 block, and what pistons should be used for a rebuild that will use LS1 241 heads. I want a pump gas friendly compression ratio.
Quick Reply: LQ9 - LS1 interchange able parts?
