Removing sticker glue
Hi,
I have just removed the OEM stickers from under the hood, and I think it looks a lot better.
I used an addhesive remover and it worked well, but the glue under the sticker on the battery is resisting my addhesive remover.
Any surgestions for removing this glue?
goo gone, wd40, lighter fluid, paint thinner will all take it off. if it's in an area that doesn't matter much, you can even use fine sandpaper, then polish the area out afterwards.
Hi,
Thank you for all the replys.
I used the 3M Adhesive remover for the glue and it worked perfectly on all the stickers except the battery one, which was a different type of glue.
So as project98LS1 said I tried wd40 and it came right off.
Thanks for the help,
Hope this helps someone else out too,
Paul.
Paul.
