Finally, 700+ rwhp stock LS2 = BOOM
Old 01-30-2008, 09:56 PM
FastBlackTA's Avatar
Default Finally, 700+ rwhp stock LS2 = BOOM
It finally let go...same old story, too much timing. 14 psi, completely stock LS2 down to the valvesprings. No idea on power but on 13 psi and less timing it was around 680 rwhp 700 tq. Too many 4th and 5th gear highway pulls to count (motor let go on highway 5th gear pull). Car has been daily driven for the past month at 12-14 psi (about 1500 hard street miles). APS TT system.
If anybody out there has a stock LS2 shortblock they would like to sell, please PM me. Time to do forged rods/pistons....
Old 01-30-2008, 10:02 PM
Tiago's Avatar
is that on c6? lol NICE
Old 01-30-2008, 10:06 PM
TT-TECH Veteran
Inspector12's Avatar
I assume so as in his signature Tiago. Held up pretty well considering IMO.
Old 01-30-2008, 10:07 PM
Yeah....esp considering it's daily driven on that boost!
Old 01-30-2008, 10:47 PM
chromeplated500's Avatar
wow... so does this mean that you have an excuse to build something bigger??? haha
Old 01-30-2008, 11:05 PM
Websy21's Avatar
You were asking for forged internals now weren't we. If I only had money to burn, LOL It scares me to see the guys that do these kind of things b/c you don't wanna even guess what comes flying out of the shop after its been fired up once again
Old 01-30-2008, 11:36 PM
Loboost's Avatar
Man that did not take you long just curious were running straight 91 or were you using any additives etc? PM if you need any ideas on the build up.
Les
Old 01-31-2008, 01:24 AM
allthrotle's Avatar
O well time for something bigger and better with more hp's
Old 01-31-2008, 01:27 AM
Grr
Grr's Avatar
so, how much timing were you running? Just curious cause i dont want to go that high obviously!
Gary
Old 01-31-2008, 02:41 AM
ringram's Avatar
High teens timing?
In fact Id even say mid/low teens with that pressure and compression.
Old 01-31-2008, 06:19 AM
Reject's Avatar
what, no pix of the rod hanging outside of the block?!
Old 01-31-2008, 06:34 AM
Les
No additives, meth, 93 octane, timing in the high teens....
Old 01-31-2008, 08:23 AM
geeteego's Avatar
Ouch. I feel your pain.
GL on the rebuild!
Old 01-31-2008, 08:48 AM
GXPJAY's Avatar
Wow, that much power on stock LS2 valvetrain, never any valve float or misfires? What were reving it up to?
Old 01-31-2008, 08:52 AM
Les
I think one of the big differences between your stock shortblock build and my own is the lower compression heads you had on your car. I would assume that makes a difference on cylinder pressure.
I might throw another stock motor back in it for the time being. I think I have one locked down....
SSilverSSurfer's Avatar
bout time someone doesnt get scared to push it hard knowing its gonna blow. +1 for picks of carnage
Old 01-31-2008, 08:55 AM
B18CYA's Avatar
wow thats a ton of boost with that compression. kinda makes you wonder how long it could have lasted at like 12 psi with a little less timing.
Old 01-31-2008, 10:05 AM
Shon Herron's Avatar
Sweet!!
Old 01-31-2008, 11:39 AM
black01_WS6's Avatar
thats what I was thinking.
Old 01-31-2008, 11:51 AM
SovXietday's Avatar
Keep boost the same, take like 4 degrees off the timing.
OR
Keep the boost the same, take 2 degrees off the timing... and then don't do anymore 5th gear pulls! Any gear under a 1:1 ratio is going to make your engine work a shitton harder which obviously builds up a lot of heat and starts detonating like it's cool.
Nice numbers though!
Quick Reply: Finally, 700+ rwhp stock LS2 = BOOM
