use cereal box for gasket?
Old 02-03-2008, 12:23 PM
Boosted 99 TA's Avatar
Default use cereal box for gasket?
hey guys i just bought a pro 5.0 shifter and i was reading some threads about people not liking the fact of using rtv to seal the new shifter to the trans..so i was thinking do you think cutting a cereal box for a gasket would work fine and help reduce the noise from the shifter?
Old 02-03-2008, 12:28 PM
flyinZ's Avatar
I dont know about noise reduction, but it would seal it up, far as fluid leaking out. I've used that method on several hydraulic applications at work...Only as a last resort those,lol. Cracker boxes work too
Old 02-03-2008, 04:05 PM
ae13291's Avatar
there is a special gasket set i think you can buy on ebay or somthing
Old 02-03-2008, 07:15 PM
thesource's Avatar
<------- Uses black RTV
Old 02-03-2008, 09:19 PM
ss1
ss1's Avatar
It might work, i've never really thought about it being the same type of material as an actual gasket. Fwiw, my local hardware store had small rolls of gasket material on the shelf.
Old 02-03-2008, 09:30 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
yes it does work
Old 02-03-2008, 11:24 PM
would it be better to just get the gasket material..my friend has a roll of that too so i could do that i guess
Old 02-04-2008, 04:07 PM
camaroguy26's Avatar
wow never heard of cereal boxes, don't see why it wouldn't seal that up though, I don't think a lot of fluid makes it's way up there. Make a run to an auto parts store though, I found a gasket material set at advance for pretty cheap. Has 4 sheets of different materials, rubber, rubber/somethin, cork, and I can't remember, but it's helped me a crapload for numerous things!
Old 02-04-2008, 04:37 PM
3stgstocker's Avatar
make shure to use a wheaties box!!!!!!!!!! lol
Old 02-04-2008, 05:09 PM
CranMaro99's Avatar
Why not just use rtv?
Old 02-04-2008, 05:20 PM
DVS99TRANS's Avatar
I used a cereal box and started leaking fluid immediately. RTV'd it and it's been fine. That's my vote.
Old 02-04-2008, 07:32 PM
alright thanks, for the response guys.
Old 02-04-2008, 07:36 PM
chromeplated500's Avatar
rtv... like $4 works great and no leaks
Quick Reply: use cereal box for gasket?
