throttle body
Old 02-07-2008, 03:55 PM
therobman's Avatar
Default throttle body
my throttle body was ported and polished with the epoxy and everything by bo white when he used to do them i just put it on cause i completed my motor well i here like a hissing noise comming from it is that common or is something wrong?????
Old 02-07-2008, 05:22 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
Nope, sounds right. You will have more noise from the IAC with the round hole like that.
Old 02-08-2008, 02:56 PM
Bill Bowling's Avatar
Bo White did great work..
Bill
Old 02-08-2008, 08:21 PM
Bo White's Avatar
Epoxy? Were is this epoxy at?
Old 02-11-2008, 02:30 PM
therobman's Avatar
the top left corner where the holes are
Old 02-11-2008, 09:44 PM
Bo White's Avatar
I didnt do it. Was it added after I ported the TB?
Old 02-11-2008, 09:48 PM
therobman's Avatar
maybe you didint do it but i thought you did it i could be mistaken it was added when i had it done
Old 02-11-2008, 09:55 PM
Bo White's Avatar
I thought something was up when I read epoxy because I have never done one with any epoxy for a customer. Ive TIGed a few were the casting was thin on the bottom and close to the throtte shaft but never any IAC opening filling epoxy or welding(except when I was testing what did what on the dyno back over 4 years ago). Do you have a pic of the TB?
Old 02-11-2008, 10:11 PM
therobman's Avatar
i actally do
Old 02-11-2008, 10:13 PM
jkwalkercchs's Avatar
just curious why did u stop porting??
Old 02-11-2008, 10:25 PM
therobman's Avatar
sorry didint realize it was so big here
Old 02-12-2008, 08:13 PM
Bo White's Avatar
By the pic everything looks good, shapes and all. I thinned every blade I did so the factory "honeycomb" look of the blade wouldnt be on any of mine, It would be either polished to a mirror or be a satin nondirectional finish. Then when I put a TB together I always used washers under the blade screws to more evenly distribute the clamping force of the screws. Nothing wrong with that TB though, looks good
Old 02-12-2008, 08:31 PM
bo why did u stop porting?
Old 02-13-2008, 06:52 PM
Bo White's Avatar
Dont have the time anymore.
Old 02-13-2008, 08:06 PM
01 BERGER CAMARO SS's Avatar
dammit, i should have gotten one earlier. Mybe ill get havoks when he moves up to a 90/90
Havok2's Avatar
i got a bo white tb before he stopped heheh no regrets!
Old 02-28-2008, 09:39 AM
DopeFedZ's Avatar
I would be real careful with that epoxy filler piece. I just found mine inside of one of the runners of the head. It was a epoxy piece with a brass colored tube in it. Not sure what happened to the other tube because it sure isn't in the epoxy piece anymore
Old 02-28-2008, 09:48 AM
Slvr00Bird's Avatar
Damn good looking TB.. wish I had time to do something like that.. school
Old 02-28-2008, 11:33 AM
Boosted1320's Avatar
Just curious, how is it supposed to flow any more air if the inner diameter of the throttle blade never got any bigger? You could actually port the whole front of it off til nothing is left and you wont change how much it flows. ??? Kind of like a funnel, no matter how big the big end is, its never going to flow more than the smaller end will allow.....just look pretty.
Old 02-28-2008, 12:14 PM
Slvr00Bird's Avatar
The aim is to increase efficiency and speed of flow.. So if you remove a little material and all of the casting flashes, etc, then the air should flow smoother and give an increase in performance..
