Spark Plug Gap?
Spark Plug Gap?
I am running a 408 with a F1R procharger with 20lbs of boost, 116 octane fuel, autolite ar123 plugs, what should I set the gap on the plugs.
all i was saying is the tighter gap wont hurt
So you know exactly whats in my engine-dont know how you can tell me that i dont need that gap when you dont know what i have,i run way more than 35 psi at the track-thats just what i run it to on the dyno+i have a bunch of compression
since were on plugs, i would like to get a starting plug for my setup-after 40 years of s/b's, b/b's i am in future shock with a gen 3-lol
i have a 6.0 lq4, 9.2 wiseco pistons, using the stock tweaked 317 heads, z06 cam, carb'ed blowthru with a disc, prob around 10 lbs boost, vette setup with 8 rib, in a 69 chevelle
i would like to run an autolite, just need a good starting heat range-the plugs look diff that earlier gen 1's, so i guess its like everything else there a whole new ballgame also-thanks
i know my combo leaves some power on the table, but once i am up and running, then i will make changes-trying to build the car and the engine kills a lot of time (and yes i have a lot of experience with blowthrus and carbs)
