1993 Tuning/metering system?
Old 02-14-2008, 07:32 AM
azboostin's Avatar
Default 1993 Tuning/metering system?
I picked up a 1993 z28 as my first chevy project car... anyways... I noticed 93 does not have a maf? so... what do the 93's do for forced induction and tuning ect. thanks!
Old 02-14-2008, 07:38 AM
Bad93TA's Avatar
this should help u. http://www.speeddensity.org/
Old 02-14-2008, 07:57 AM
azboostin's Avatar
is there anyway to convert them to mass air
Old 02-14-2008, 08:08 AM
roadhog_113's Avatar
pretty sure you can but 93's respond to mods better from what i understand. All you need is a good tuner.
Old 02-14-2008, 08:31 AM
azboostin's Avatar
ok thanks.... I see you can have chips burned,, is there any devices that will let you datalog/tune your self instead of mail order chips
Old 02-14-2008, 10:15 AM
if you get tunercat you can change the tables yourself. Then burn the new tables into your chip.There are more programs but that is the only one i can remember.
Old 02-14-2008, 11:21 AM
qwk93ta's Avatar
I had my 93 T/A converted to mass air.....you'll need a 94+ computer and wiring harness.
Old 02-14-2008, 11:51 AM
was it worth the swap?
Old 02-14-2008, 03:33 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm also wondering that. I have a 93 also. I have access to EFI live tuning, but they don't do 93s. I could get tunercats and the items needed to burn chips, but the cost might be the same as upgrading to a different PCM. That combined with the fact the new PCMs are much more robust makes this a difficult decision.
Old 02-14-2008, 03:39 PM
Formula350's Avatar
I like TunerPro. I can send you my tune, but it's nothing special. Just improved stock, but a noticeable change. EGR/AIR removed though.
Quick Reply: 1993 Tuning/metering system?
