walbro 255lph
walbro 255lph
I was curious on what size fitting you guys recommend to use with the walbro? I am running an ls1 with hopefully twin turbos and around 600-700hp. Also not sure if it matters but it will be an intank setup. Thanks Josh
I was told it was. Do you have a recommended pump that i could use? I looked at the aeromotive setups but they got real pricey real fast so i am open to ideas. Thanks alot
Josh
Josh
I am new to this so If i were to use two walbro's how do they tie together or is it as simple as it seems? What size an fitting would you recommend for suppy and return if i end up running two of them? I am also going to look into that ford gt pump. It sounds promising also. Thanks alot
Josh
Josh
I looked at the bosch 044 pump. It looks like it would work great and i would only have to use one pump which would simplify everything. Would you guys still recommend -8 AN fittings with this pump or -6 AN fittings? What about -8AN for supply and -6AN for return or is it better to run the same sizes? Thanks alot for you help.
Josh
Josh
Added info..
Maybe look at this thread??
http://www.turbobuick.com/forums/gen...ve-spoken.html
Seems as tho the WABRO engineering folks have added feedback...
