IAC's How else can i get them down?
Old 07-15-2003, 06:35 AM
z28man's Avatar
Default IAC's How else can i get them down?
I'm trying to get my IAC count down to about 30-50. i drilled up to about 3/16" dia. hole. im still reading about 75 at warm idle. should i drill bigger or is there another way. i dont want to drill to big and have it mess things up! thx in advance!
Old 07-15-2003, 03:10 PM
Cal
Cal's Avatar
Default Re: IAC's How else can i get them down?
Do you mean you added a second hole that size? Anyway, If you're worried about making the hole too big, try using the idle stop screw to let some more air through; it will be pretty touchy, but at least you can put it back.
Old 07-16-2003, 01:00 AM
Ed Blown Vert's Avatar
Wouldn't the PCM learn it out??
Old 07-16-2003, 11:22 AM
Cal
Cal's Avatar
The PCM will drive the IAC to what ever count it needs to get the airflow right no matter what size the hole or holes are . . . BUT if the hole is too small or too large, the motor may not have enough adjustability to dial it in; it will be out of range. That's why the hole size has to match the cam size. For example, the stock TB hole on my car with the TR224 works fine until I turn on the AC, then it can't flow enough air even with the IAC counts maxed out.
Old 07-16-2003, 11:29 AM
Ahh, since I think the max is 127. And I am @ 90. I shouldn't have to drill. Or should I still try to get them under 70?
Old 07-16-2003, 11:55 AM
Ragtop 99's Avatar
You could try changing the IAC table in Edit too.
Ed: I would leave the TB alone if your idle and low speed drivability are fine.
Old 07-16-2003, 12:04 PM
I am just fighting a small surge @ off-idle. Otherwise, I have it tune pretty good. Idles fine with no stalling. Would drilling help in that area?
Thanks.
Old 07-16-2003, 04:08 PM
Cal
Cal's Avatar
Yes, on an A4 drilling the TB will help with surging. Just don't drill it too much; the biggest I've heard of anybody going to is 0.250 inch, and that was with a 230 duration cam. It's best to drill one size at a time.
Old 07-16-2003, 04:13 PM
Ragtop 99's Avatar
I would only go up 1/16 at the most. Too high and you get a cruise control effect from the extra air.
Old 07-16-2003, 04:16 PM
Thanks I have that cruise control sometimes. I will have to see if I can get a spare TB or blade just in case I screw up.
