Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Our Top Sportsman truck is almost complete!!
Old 02-20-2008, 08:48 PM
WickEdSix98's Avatar
Default Our Top Sportsman truck is almost complete!!
After a year and a half we only have very minor details to be completely done!! We finally got a new set of dominators and re-dynoed this past weekend and the engine made 1104hp 818tq. Its a 565" BBC with a Dart block, RHS 320's, 3 stage dry sump, 16.2:1, etc. all done by Abbott Racing Heads/Engines. Can't hardly wait to get it on the track!!
Old 02-20-2008, 09:34 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Looks good! Did you completely build it or was it a roller purchase?
Old 02-20-2008, 10:05 PM
The chassis was built by Smith Racecraft for PST but we had to have a lot of extra work done to get a big block and a powerglide in it. We built the motor and did pretty much all of the other odds and ends.
Old 02-20-2008, 10:30 PM
dodgn bullets's Avatar
Lookin damn good man!
Old 02-21-2008, 03:55 PM
6 & 8 Second Club
mrdragster1970's Avatar
Welcome to the club. Have fun.
JBL T/S 368E
Old 04-17-2008, 06:16 PM
First time out with our truck at Abilene. We were trying to run Texas Pro Stock and only made three passes before the transmission broke. Converter is too tight and we had to add 253lbs so it would weigh over the minimum of 2500. Weighs 2515. Best pass was a 5.00@138 with a lot more tuning left. We hope to go low 4.8's next time out with the changes we're making.
Attached Thumbnails Our Top Sportsman truck is almost complete!!-041208-100.jpg   Our Top Sportsman truck is almost complete!!-041208-451.jpg   Our Top Sportsman truck is almost complete!!-041208-188.jpg
Old 04-18-2008, 04:26 AM
6 & 8 Second Club
How in the hell did you brake a trans?? at 5.00. Something quick & cheap I hope.
Good luck.
Old 04-18-2008, 09:02 PM
Good luck.
It was a stupid mistake. Didn't get the converter in all the way when we had the TCI pump in it the first time and it tore that pump up so we put a stock pump in it we had laying around and it spun the staitor(sp) tube out.
Old 04-18-2008, 11:34 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Are you runnig it on gas or alcohol?
Old 04-19-2008, 03:22 AM
6 & 8 Second Club
Human error, you have to love it. At least you didn't explode a planet or something big $$.
Good luck.
Old 04-19-2008, 09:27 AM
Gasoline. The 5.00 was on VP C15. We still have two other fuels to try that are worth 30-40HP. Alcohol is a 50lb weight penalty. http://www.texasprostock.com/tpsarules.html are the rules for TPSA.
Human error is a bitch though. It ended up toasting the band. The high gear drum had a huge groove cut into it. Reverse clutches were toast. On the last attempt at a pass, when I hit the T-brake and nailed it, the motor went straight to the 8800 high side chip.
Old 04-19-2008, 12:21 PM
JUICED96Z's Avatar
Dont feel bad, I was putting the an connections back into my fuel pumps and did not know they are pipe fittings.......
Quick Reply: Our Top Sportsman truck is almost complete!!
