what pulley for 9psi on a p1 procharger
Old 02-25-2008, 09:39 AM
transdam's Avatar
Default what pulley for 9psi on a p1 procharger
the car is a stock 02 with headers and true duels no idea what pulleys are on it now would like to have 9-10psi (stock 6rib about 900ft elevation)
Old 02-25-2008, 06:47 PM
EPP
EPP's Avatar
Most likely a 3.55 would be close. Bob
Old 02-25-2008, 07:57 PM
Rickys S/C Z28's Avatar
cool man good luck
Old 02-25-2008, 08:36 PM
kwiksilverz28's Avatar
3.70" at basically sea level on stock motor with headers and magnaflow cat back made 5.1. I upped to 3.40" in search of 6.5-7. A 4.10 made 3psi with manifolds and a cut out....
Oh, and 6 rib set up
Old 02-25-2008, 10:37 PM
One Bad Z's Avatar
find out what pulley you have now before you order anything! Pulley & belt isnt cheap and if you have someone else doing the install you will just waste $ if you get the wrong size pulley.
3.2 pulley on a stock setup is good for about 8lbs
3.0 pulley on a stock setup should be around 10lbs but might run into belt slip issues.
Old 02-26-2008, 04:47 AM
EPP
EPP's Avatar
Question
That sounds way too small to me. With the old 6 rib D-1SC system, I made 7 lbs of boost with the 7.00" crank pulley and a 4.00" blower pulley. If you have a faulty by pass valve it can take a lot smaller of a pulley to make boost. We replaced a brand new Pro Flow bypass valve with another new one and picked up two pounds of boost several years ago when the boost we were seeing just didn't seem right on a V6 Mustang. Bob
Old 02-26-2008, 04:53 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
With the SDCE 7.25 crank pulley and a 3.4 pulley my former P1SC put out 10 psi. Baby cam, full exhaust and stock heads.
Old 02-26-2008, 10:36 AM
One Bad Z's Avatar
I thought that too but with a 6rib 3.2 pulley on a stock '01 ls1 with just a corsa catback made around 8lbs. This was with one of the older kits. 3.5 intercoolers, plastic plenum, and the old bypass valve.
My setup with a 3.2 pulley only makes around 5lbs. We are putting a 3.0 on there now along with a 4200 torque converter. See what happens.
Old 02-26-2008, 10:40 AM
CALL911's Avatar
I personally would think that it also will have to do with your setup. I am pulley'd for as much boost as possible with my D1SC, but others have achieved more boost as they have different setup (example., different cam, restrictive vs non-restrictive heads, and intake combo).
Basically what I am saying is you should go with One Bad Z's advice and see what pulley you have first, and what boost you are currently seeing. Then figure out how much of a smaller pulley you'll need.
Some times extra boost is as easy and freeing up restrictions. By changing to a larger air filter, and different larger inlet tube to the blower, I picked up 6#'s of boost without doing anything else.
Old 05-05-2008, 09:57 AM
transdam's Avatar
does anyone make a lager crank pulleyfor the 6 rib
Old 05-07-2008, 08:14 AM
transdam's Avatar
pulled blower off and i have a 3.2 pulley for 7.5psi should i get a 3.1 or a 3.0 for 9psi crank pulley is almost 6 inches
Old 05-07-2008, 08:47 AM
BLNLS1/RX7's Avatar
Hes right.
Quick Reply: what pulley for 9psi on a p1 procharger
