Idle RPMs drop below what is set in Edit....why?
I have my idle RPM set at 1050 in gear and park in LS1 Edit, but when I put it in gear it drops below 1000 and stalls out. Any ideas why it would do this? How can I fix it? Thanks!
Re: Idle RPMs drop below what is set in Edit....why?
did you drill the throttle blade, or adjust Idle air and timing in edit? with that cam I would think you would have to compensate at idle.
Yeah, the TB hole is 1/4", I didn't adjust Idle Air, what should I do to it?
I lowered the timing at idle, and I upped the IAC in Park values a little.
lowered the timing at idle? hmm, I raised mine. idled much better when I upped it. wonder if that might be part of it...
though I have an M6 not A4
Right now I have the idle set screw to keep it running at almost 2000 RPM, they are about 90-100. I think I might need more air to keep it idling lower, anyone know what I need to change my Idle Air values to?
I multiplied my IAC Park values by 150%, I couldn't find anywhere to change them in gear, where would I do that at?
It will idle in Park, the problem is when I put it in gear, it dies. I thought if it idled fine in park but started hunting when you put it in gear, that was a sign of too much timing? Either way, it still won't hold the idle now, so I might as well change it back.
Thanks for the tip on IAC Park thing.
Okay, so are you saying that changing the Idle Air table won't affect how it idles in gear? I realize that there isn't a table named Idle Air in Gear, I was asking if I should modify the Idle Air table at all.
I'd try jacking up the RAF (in gear) and see what happens; it's easy enough to change it back. I tried scaling mine by 120% yesterday and didn't notice anything different, so I changed it back. BTW I'm a M6 so that may not mean anything to you.
That's the same table you were refering to as "Idle Air in Gear" I believe. If you go to "Idle Air" first, then you get a window that says "Running Air Flow" hence RAF. You then have a line for both "in gear" and "In neutral." I'm saying leave "In neutral" RAF alone but jack up the "in gear" RAF and see what happens.
