Is this leak from my slave? *Pics*
Old 02-26-2008, 12:19 AM
BayAreaSS's Avatar
Default Is this leak from my slave? *Pics*
I found this leak coming from my transmission. This looks like its coming from the bolts at the bellhousing. Can you guys help me out? Is this my slave?
Old 02-26-2008, 12:29 AM
ErikElvis's Avatar
Its hard to tell from the pics but it could be a few things. Could be a leaky slave. Have you bled it lately? Could be oil, possibly the rear main seal. Or could just be a lil leak from the oil drain plug/filter.
Old 02-26-2008, 12:37 AM
2000 cam'n SS's Avatar
Hard to tell but it looks like motor oil....Id check the rear main
Old 02-26-2008, 12:38 AM
BayAreaSS's Avatar
Yea it was hard to take pics under there. The reason i think its the slave is because the fluid looks to be burnt brake fluid from the clutch. As soon as i put my cam in the clutch couldn't handle the power and i found the leak. The fluid was black in the resevoir even though i changed the fluid regularly. I think the new found power was too much for the clutch. It is even hard to shift at high rpm's
Old 02-26-2008, 12:42 AM
KyleLs1's Avatar
i had the same leak, very minor looking, few drips under the car every few days... turned out to be the frost plug in the end of the crankshaft (right behind the pilot bearing)
you will have to pull the trans, if it is not leaking from the slave or the rear main... chances are its the plug.
good time to do some upgrades in there if you haven't already!
Old 02-26-2008, 12:44 AM
Good idea...I would go ahead and make all those changes now and fix all the seals while its apart
Old 02-26-2008, 12:52 AM
BayAreaSS's Avatar
Well i plan on getting a new clutch installed in the next week or two so i guess i'll have to wait to what the leak is. I just assumed it was from the slave because the clutch half *** works at higher rpm's now.
I'll tell you guys what the fluid is tomorrow. I'll check and see if the leak is on the ground.
Old 02-26-2008, 12:54 AM
BayAreaSS's Avatar
I'm 98% sure it is not oil.
Old 02-26-2008, 12:55 AM
ErikElvis's Avatar
Yeah if your getting a new clutch you def should be able to tell where its coming from. I know the slaves are finicky when being tightened after being bled.
Old 02-26-2008, 12:57 AM
BayAreaSS's Avatar
yea i'll just have to wait and see. But i hate waiting. I hope its just the slave because thats any easy fix and i was replacing it anyway
Old 02-26-2008, 01:03 AM
ErikElvis's Avatar
The rear main seal is a pretty easy fix as well. So you'll be alright whatever you find.
Old 02-26-2008, 01:07 AM
BayAreaSS's Avatar
Thats good to know thanks man.
I'll update this thread tomorrow when i know exactly what the fluid is.
Old 02-26-2008, 09:22 AM
KyleLs1's Avatar
i didn't think it was oil leaking when it happened to me because it was black, but what happens is, it leaks into the bellhousing, gets onto the clutch, and by the time it makes its way out the bottom it is not a pretty color
good luck man, hopefully it wont be too painful
Old 02-26-2008, 03:23 PM
McMuffin's Avatar
my cam sensor seal was leaking...i had to pull the intake to replace it. also my inputshaft seal on the tranny was leaking too.
Old 02-27-2008, 12:22 AM
BayAreaSS's Avatar
Ok guys i got under there and took a quick sample of the fluid that is leaking. It seems to be brake fluid that has turned black. It does not feel or look like oil which makes me happy
Old 02-27-2008, 02:55 PM
96lt1ss's Avatar
Yeah it looks like brake fluid.
Old 02-27-2008, 07:13 PM
BayAreaSS's Avatar
I just have to take it easy until i get the new clutch and break it in. I can't enjoy the new power for a while
Quick Reply: Is this leak from my slave? *Pics*
