36# or 42# injectors
what injectors should i get since im going to be getting new heads? i was thinkin about the 42# ones in case i decide to hook the nitrous back up but would it run fine with out nitrous as long as its tuned properly? also what brand should i get?
thunder racing cam-230/236 .592/.602 112 LSA
fast intake-92mm
fast throttle body- 92mm
patriot gold valve springs
thunder racing hardened push rods
strange S60 rear end
411 gears w/ easy locker
35 spline axles
BMR springs
BMR panhard bar adjustable
BMR adjustable torque arm
txtralia clutch
upgraded flywheel
Z06 hydraulics for clutch
steel driveshaft
mti airlid
pro 50 shifter
pacesetter headers
3" y pipe w/ cut outs and slp loudmouth
nitto 555Rs
fast intake-92mm
35 spline axles
BMR springs
txtralia clutch
upgraded flywheel
steel driveshaft
mti airlid
pro 50 shifter
pacesetter headers
nitto 555Rs
