Oil light is staying on
Old 03-01-2008, 02:48 PM
z28_YOU_HO's Avatar
Default Oil light is staying on
Ok everytime i go to start up my car the "change oil" light comes on and stays on for about 2-3min...after this its fine and does not come on anymore..oil is fresh and up to almost full on the dip stick..any ideas?
Old 03-01-2008, 03:50 PM
jester177's Avatar
you need to reset it, i cant remember exactly but check the owners manual; turn the ignition on but dont start it press and hold the trip/odo reset thing for like 20 seconds turn ign off and start it should be reset.
Old 03-01-2008, 03:52 PM
jebuzws6's Avatar
might just be a sensor acting up.. mine those the same thing, but as long as I change it every 3000 miles I think i will be ok... if you find out what it is let me know too
Old 03-01-2008, 03:53 PM
jebuzws6's Avatar
ima try that .. thanks
Old 03-01-2008, 04:33 PM
z28_YOU_HO's Avatar
Did that work for you?
Old 03-01-2008, 05:39 PM
CuriousGeorgeZ28's Avatar
yea jester's right, i had the same problem...put the car in the iginition position, or even if the car is on...it doesn't matter, press and hold the trip/odometer reset **** for 12 seconds, it will turn off and not come back on again until the computer hits the next 3000 miles
Old 03-01-2008, 06:29 PM
z28_YOU_HO's Avatar
Sweet thanks
Old 03-02-2008, 12:26 AM
02 BLK WS6's Avatar
This is how I reset mine.
Turn on ignition (do not start) and press the gas pedal 3 times quickly to the floor and turn off ignition. Start car and check to make sure the light stays off.
Old 03-02-2008, 01:57 AM
ZV8
ZV8's Avatar
wow, didnt know I can do this either, I dont have to write down my miles anymore? nice lol
Old 03-02-2008, 03:32 AM
((((((Administrator))))))
CRAGER's Avatar
> you
Old 03-02-2008, 09:15 AM
waiting2bl33d's Avatar
your 100% on everything except for the time.
the F-body oil change system kinda sucks it goes off how the users operates the vehicle to some degree you can go anywhere between 3,000-8,000 miles before it will kick on.
the big thing is change the oil how you want to just don't forget to reset the light. because the comuter has no idea when you change the oil.
Old 03-13-2008, 11:41 PM
kudos....
didnt know that one
Old 03-13-2008, 11:51 PM
SS#2906's Avatar
Won't this flood the engine with gas?
Old 03-14-2008, 12:05 AM
2000Hawk's Avatar
^ No
I don't follow the change oil light, i worry that thing might not come on when it should. Just keep track of your mileage, then just reset change oil light when you change the oil.
-Joel
