64 Chevelle LS1 swap started
Sweet ! im doin the same swap right now. LS1-T56.Im new to this sight,
Im about to fire it up and do some tuning. i just got the computer back from arizona TPI, i had'm take out some of the codes; theft, auto idle,etc.. The painless kit was easy. Cant wait to see more pics.!!!
worked on gettin the alternator figured out, i think there's enough clearance between the housing and gearbox, but the pulley is only 1/8" away..i have an overdrive pulley I can use if i have to...will look for a smaller rag joint or do away with it completely....
been slow goin so far due to trying to fix some corrosion damage in some areas and general cleanup overall, especially on the underside of the floorpan, but got the body back on and got the firewall smoothed (for the second time) and the motor/tranny, brake booster and clutch master installed, also got the front and rear AirRide suspension components installed as well as all new front steering components along with an 1 1/8" front Adco swaybar
not much to report, got the clutch reservoir mounted and put heat shielding on the clutch line...I ditched the rubber line for the clutch res and bent up a steel line because the weird angles it has to run was puttung a strain on the clutch res and i thought it would break over time
