e-85 help with boost
i was planing around all normal things i know. where on a boosted motor i needed like a 9:1 compression motor. well if i run e-85 which basicly is like 100 oct. then can i run like 9.5:1 or 9.8:1?
please help. thanks
please help. thanks
You'd be better of keeping the compression at 9:1 and running more boost with the e85. It will be less stressful on the engine, and probably make more power than running higher compression with less boost.
We just got E85 in Albany NY... cant wait to take advantage of it.
On topic, You can change your boost but you cant change your static compression with a ****. Just something to keep in mind.
LS1Tech Co-Founder
We have a lot of E85 around me (Chicago/IL), but I'm doing a little research and if I wanted to convert I might have to change my gas tank. I'll ask this guy I know to go over my combo and see what issues he sees. He's an E85 specialist.
my turbos max out at 18psi. which if i was running 91 oct i would still run 18psi. so will e-85 can't run anymore boost. so raising compression. will add power, right?
and john if you have a stock tank you are fine. e-85 aint as cerosive as people think.
His is a 98 (steel)
Edit: WAIT... there is a public one, first in Phoenix, but it a ways from my house in North Phoenix
Western States Petroleum
450 South 15th Avenue
Phoenix, AZ 85007
602-252-4011
View Map
Downtown Phoenix, between Jefferson and Grant on South 15th Avenue. First public station in Phoenix!
That's the Arizona Dept of Administration and I'm pretty sure it's private people (or Gov use) only
Phoenix, AZ 85007
602-252-4011
View Map
Phoenix, AZ 85007
602-252-4011
View Map
i was reading over on turbo forums a couple people put a bunch of parts in e85. One guys test lasted over a year. He said the bare aluminum was fine and all the rubber parts and hoses did the same stuff the gas would do to them. I am still not sure about running an aluminum cell but i think it is my only option.
