e-85 help with boost
Old Mar 4, 2008 | 07:50 PM
Big Bird WS6's Avatar
Default e-85 help with boost
i was planing around all normal things i know. where on a boosted motor i needed like a 9:1 compression motor. well if i run e-85 which basicly is like 100 oct. then can i run like 9.5:1 or 9.8:1?
please help. thanks
Old Mar 4, 2008 | 08:28 PM
MECHAM's Avatar
just run more boost
Old Mar 4, 2008 | 08:53 PM
ONEBADASSWS6's Avatar
please help. thanks
You'd be better of keeping the compression at 9:1 and running more boost with the e85. It will be less stressful on the engine, and probably make more power than running higher compression with less boost.
Old Mar 4, 2008 | 09:04 PM
Cchris1109's Avatar
i wish they had E-85 in phoenix, arizona
Old Mar 4, 2008 | 09:21 PM
kbracing96's Avatar
You and me both
They do, but you would have to go down town and steal it!!
Old Mar 4, 2008 | 09:25 PM
Cchris1109's Avatar
i know on 15th ave and madison they have it, or is that for private people only
stealing is ok :-D
Old Mar 4, 2008 | 09:30 PM
Johawk's Avatar
We just got E85 in Albany NY... cant wait to take advantage of it.
On topic, You can change your boost but you cant change your static compression with a ****. Just something to keep in mind.
Old Mar 4, 2008 | 09:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
We have a lot of E85 around me (Chicago/IL), but I'm doing a little research and if I wanted to convert I might have to change my gas tank. I'll ask this guy I know to go over my combo and see what issues he sees. He's an E85 specialist.
Old Mar 4, 2008 | 09:42 PM
my turbos max out at 18psi. which if i was running 91 oct i would still run 18psi. so will e-85 can't run anymore boost. so raising compression. will add power, right?
and john if you have a stock tank you are fine. e-85 aint as cerosive as people think.
Old Mar 4, 2008 | 09:49 PM
Jake@EPP's Avatar
His is a 98 (steel)
Old Mar 4, 2008 | 10:03 PM
Johawk's Avatar
All gas around here is 10% ethanol anyway. Ethanol is nowhere near as bad as methanol which people commonly get confused about.
Old Mar 4, 2008 | 10:23 PM
kbracing96's Avatar
stealing is ok :-D
That's the Arizona Dept of Administration and I'm pretty sure it's private people (or Gov use) only
Edit: WAIT... there is a public one, first in Phoenix, but it a ways from my house in North Phoenix
Western States Petroleum
450 South 15th Avenue
Phoenix, AZ 85007
602-252-4011
View Map
Downtown Phoenix, between Jefferson and Grant on South 15th Avenue. First public station in Phoenix!
Old Mar 4, 2008 | 10:49 PM
LS1Tech Co-Founder
Actually I have a custom sheet metal gas tank.
Old Mar 4, 2008 | 11:42 PM
Cchris1109's Avatar
Phoenix, AZ 85007
602-252-4011
View Map
Hmmmmm I may convert I will just buy drums on drums, well worth it IMO
Old Mar 5, 2008 | 12:33 AM
ls1408cp's Avatar
i was reading over on turbo forums a couple people put a bunch of parts in e85. One guys test lasted over a year. He said the bare aluminum was fine and all the rubber parts and hoses did the same stuff the gas would do to them. I am still not sure about running an aluminum cell but i think it is my only option.
Old Mar 5, 2008 | 05:18 AM
well 91/93 oct around here is like 3.30 a gallon and e-85 is like 2.40 a gallon. so if i lose 20% gas milage i still come out on top
Old Mar 5, 2008 | 06:20 AM
Johawk's Avatar
over here E85 is 2.60 and 93 is 3.50+ so its about the same if not cheaper on E85
Old Mar 5, 2008 | 07:06 AM
1INSANEGTO's Avatar
I don't see why you can not run E85 on 10:1 just a choice. Alot of people do not like to step over the unknow line. I have a friend running 10.5:1 with twin 76's but he is alky
Old Mar 5, 2008 | 08:13 AM
smokinHawk's Avatar
please help. thanks
yes you can run it at 9.5:1 or 9.8:1, my personal choice would be 9.5:1 and try to squeak out more boost, but you probably still could run allot on 9.8:1
Old Mar 5, 2008 | 09:13 AM
LS1Tech Co-Founder
I read that E85 is like 105 octane.
