18" Z06 rims
18" Z06 rims
im lookin at a 305 35zr 18 nitto nt555r's 280$ a piece, and 295 35 18 bfg kdws for 240$ a piece. wondering which is a all around better tire. and i was thinkin 275 35 18 for fronts not sure. im trying to do no fender curling or anything like that. rears are 10.5 fronts are 9.5
which is best tires to go with.
Get the Vredestein (2) 275/35/18 & (2) 295/35/18 for $649 plus $75 to ship from TomzWheels.com
https://ls1tech.com/forums/showthrea...ght=tomzwheels
Let us know how you like them.
305's are a waste of the extra money! Get 295's! If you put them side by said they look the exact same! I can get 295/35r18s for 200$ each and they are a great tire!
305/35's = 26.4x12.04
295/35's = 26.1x11.70
So the 305's r only .34 wider! Now worth the extra $40-$80+ more per tire
toyo tires here http://www.tiredeals4less.com/?gclid...FRFBFQodmkwx_A
I had both those tires. If you are looking at the Nitto 305 Drags then IMO they are better than the BFG's. Stiffer sidewall and just better overall construction.
Better traction. Only thing the Nitto will wear faster
All the above applies to the Drags only. If you get the regular 555's then the BFG would be my choice.
forget the numbers..... The nittos flat out look bigger and hook better. Unless you've had both, like I have, you can't talk. You'll be happy with your decision just run the rears around 23-25psi, it will hook better and the centers won't wear out as fast
