When changing lifters!!!
Old 07-21-2003, 03:21 AM
SSG-Z28's Avatar
Default When changing lifters!!!
Is there anything I need to pay special attention to when putting everything back together. I know the torque specs, but if anyone has any additional advice, I would appreciate the help..
Old 07-21-2003, 03:23 AM
jmX
jmX's Avatar
Default Re: When changing lifters!!!
Soak em in oil first and do NOT overtorque the bolts for the plastic lifter cup (you'll pull the threads right out). I'd probably use a little locktite on them too.
Old 07-21-2003, 06:51 AM
SSG-Z28's Avatar
Thanks, any advice with the head gaskets or anything else?
Old 07-21-2003, 07:00 AM
Hannibal's Avatar
Definately soak them in some oil overnight. Simple preventative medicine.
Old 07-21-2003, 07:03 AM
SSG-Z28's Avatar
Thanks, I guess that's an important step.
Old 07-21-2003, 08:53 AM
MOBE's Avatar
If your installing new lifters, clean them up with some mineral spirits first to clean out any gunk build-up from packing. Then soak them in oil.
Old 07-21-2003, 10:18 AM
Assassin's Avatar
for the head bolts, I had a hard time getting a clar view of the rear center bolts on each side, if you got a digital camera handy, reach back and take a pic so you can see the mark you put on more easily, though of this after I was done of corse!
Old 07-21-2003, 10:29 AM
Cal
Cal's Avatar
Or you could use a very old-fashioned device known as a mirror! :p
