Subframe Connector ??
I got a good deal on some SLP Bolt On Subframes that are brand new and never been used, I have heard a few people tell me I should weld them in even though they are supposed to bolt right up is there really that much of a difference or should I just bolt them up and leave them be?
I look at it this way: If you bolt them up, they WILL loosen after awhile.
But if you weld them they won't.
If you don't think that way, then bolt them up.
Either way, it's ultimately what YOU want.
Scott
Scott
I am not one that just goes the easy route thats why I ask others opinions some people have experience and I dont want to have to keep tightening the bolts every so often I didnt know if loc-tite would hold or if I could just have someone weld on the bolt on subframes
I have boxed sub frame connectors, bolt in and used loc tite, never once have they ever needed to be tightened up. I installed them around 2003 and was my daily driver and car has made 200+ passes at the track and they still are perfect. About 3 months ago I changed the oil and decided it would be a good time to check the sub frame connectors, not loose at all. So I would say bolt in works just fine with no constant tightening. Also keep in mind, depending on what type of SFC's you have they may need to be unbolted to install a new catback etc. I did once need to loosen 1 side when I was putting in a driveshaft safety loop and catback adjustment.
I have UMI 2pts that are bolted in and I havent had them loosen up yet, given theyve only been on for a few thousand miles.
FWIW I used loctite and the hardware they supplied with the connectors.
How many parts on our cars are just bolted in and not welded? With that said how often do you end up tightning everything up? I figure this is nothing different.
I prefer to only bolt mine in because I might wanna sell the car and if I do I rather demod it and sell the car stock and the mods separate and unbolting is way easier then cutting welds.
getting them welded is just an extra precationary. like its said most have never come loose but you never know. a lot of people get them bolted up and then just weld them for the hell of it. if your racing a lot i would get them welded. just my 2 cents.
