Tapping Tank On Griffin Rad
Old 03-13-2008, 10:13 AM
blazin's Avatar
Default Tapping Tank On Griffin Rad
Has any one had success with tapping a hole in the tank of the griffin radiator. I need to tap a 3/8 hole for a coolant temp sensor but wanna make sure its thick enough to get enough threads to hold. Anyone do this with any luck?
Old 03-13-2008, 10:25 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
why not buy a aluminum bung and weld it on that way you know u have enough?
http://store.summitracing.com/partde...5&autoview=sku
Old 03-13-2008, 10:40 AM
DeltaT's Avatar
+1 that's the right way to make it strong enough to handle the vibration.
Jim
Old 03-13-2008, 10:42 AM
blazin's Avatar
Thats what I was figuring. I need to find one local so I dont have to pay 11 dollars freight on a 4 dollar part.
Old 03-13-2008, 10:44 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
dude it's summit, im sure you can find $20-30 in parts you need....
Old 03-13-2008, 11:19 AM
DeltaT's Avatar
Any local shop will happily make one for you for $25!
Jim
Old 03-13-2008, 11:37 AM
blazin's Avatar
Ya I know summit is the shiz.
Old 03-13-2008, 11:44 AM
smokinHawk's Avatar
i welded a bung to mine, the wall isnt thick enough to tap
just say you want to return the part, and they will refund your money and you get to keep the part as it isnt worth them to pay for shipping to get the part back, least they did that a couple of times when i needed to return something cheap
Old 03-13-2008, 01:38 PM
blazin's Avatar
I just placed a order early this week and two last week with em so they were kind enough to waive the shipping on the 5 dollar part. A++
Old 03-13-2008, 03:05 PM
DeltaT's Avatar
Also this works with Summit: If you have an order pending, you can add stuff to the order and it is covered under the original service charge. This only works until the last piece ships and the order closes. Perhaps someone clever could look for a part backordered for a while? Sort of blanket shipping coverage...
Jim
Quick Reply: Tapping Tank On Griffin Rad
